I need some help with a p2k with sound. Lastnight I was running the loco, all was fine until I pressed the F10 button then the loco said ID no. 5 disconnect. Nowthe loco will only rev up and make sound and not move at all. I dont know what to do at this point Ive tried evereything. Any ideas will be appreciated. The controller is a Dynamis. Thanks Dave
Press F6 twice to revive the patient. When all else fails, read the instructions that came with the locomotive. It contains a QSI sound decoder. F6, F9, and F10 control the startup and shutdown sequences. You have put the loco to sleep when you pressed F10.
