HI evryone. I have a question about locomotives for my layout in HO scale. I need some power from the 1970-present day period to run on my long coal trains, mixed freight ect. I am running on 18 radius and need to know the biggest power i can run. Right now my biggest loco is a U-28b. Please help
It depends on what you want to run Shawn. I have one 18" radius curve & I run Athearn locomotives around it with no problems. SD40-2’s, AC4400’s & C44-9w’s. Rivarossi’s 4-6-6-4’s
I have had no problems with this corner even at full throttle. My 2 year old daughter can vouch for that.
I hope this helps
Just my 2 cents
The biggest concern you’ll run into is the longer the loco the more coupler over-hang there will be. As long as the loco doesn’t pull the coal car off the track (sorta sideways to the outside) your’e good to go.
Here are some six axle exceptions to the radius recommendation per" MR reviews" that should run on 18"
Athearn SD-2
Atlas SD35
Lifelike SD60M, although 24" is better
Kato SD80MAC w/o cars, although 24" is recommended
Kato SD70MAC w/o cars, although 24" is recommended
Atlas is coming out with a new three axle that will run on 18"
but I don’t recall the model.
In as far the coupler comment by md; perhaps substituting a longer shank
couplers on the loco/ lead car could be a solution.
Since I run 22" I have no way of testing that theory.
I think running a six-axle locomotive such as a SD or GE U33C on 18" curves is asking for trouble, even if they stay on the track often the wheels will bind and this will slow down the train. If you have a layout that has a size allowing for no bigger than 18" curves stick to 4 axle locomotives. This also has the advantage that you can multiple without the train getting too long.
Good luck
The typical coal train power in 1970s and 1980s were 3000 hp six axle diesels, mostly EMD SD40-2, with some GE C30-7 thrown in. HO scale models of both have been made; Athearn, Bachmann, GSB, Kato, BLI (announced) for SD40-2 and Atlas, RPP for the GE. Most of these will barely go around an 18" radius curve. The Atlas GE’s I had would, but the wheels squealled something awful, and the frieght car coupled to the locomotive would be derailed.
Consider going with a coal branch locomotive configuration instead. On the N&W/NS this could be two GP40’s sandwiching a slug. (see Model Railroading magazines Jan 1994, July/Aug 2000 and Aug/Sep 2000). On the CSX, the road slugs are often EMD GP30 with no engines, but with cabs, dynamic brakes and fuel tank. These are often coupled with GP40-2 locomotives.
