Locomotive shorting track
I have a Life-Like Proto 2000 diesel locomotive that was running with a Digitrax DH123 decoder. While crossing an AR1 reversing loop gap the loop shorted. I was trouble shooting this AR1 as it was not reversing for any locomotive. After a couple of times with this loco it will now not work anywhere on the layout. It shorts the track.
I know the AR1 is bad and I’m replacing it with a different brand.
I want to get the loco running again. Trouble shooting I’ve done was to remove the decoder and try it in DC mode but it still shorts so that tells me the decoder is not the problem. Could the circuit board in the loco be shorted out? Can I still find a part for this? Would it be cost prohibitive?
That’s a bummer! Maybe you can start by calling Walther’s, and see if you can get a replacement board.
Mike.
Have you opened the locomotive up and checked for loose wires that may be shorting? Bits of metal, screws and track spikes sometimes get picked up and may be stuck on the motor magnet, too. Once the shell is off, spin the motor a bit to make sure it’s not frozen up. I had one motor go bad once. The symptom was that it had a dead spot each rotation where it would short. I needed a new motor, and unfortunately a new decoder as well.
Bad news: You have probably toasted the decoder, or perhaps the circuit board.
Good news: You don’t really need the circuit board. It contains some electronics to control the lights, but that’s about it.
More good news: The DH-123 is an old, bottom-of-the-line decoder. Replacing it will not set you back much, and the next one you get will perform better.
If the decoder is a wire-in instead of a plug-in, you can remove the circuit board and just hard-wire in the decoder. This may involve adding some resistors for the lights, and yes, you’ll have to do some soldering. If it’s a plug-in decoder, you might be able to get a harness which will convert it to a wire-in.
Or maybe it’s telling you it’s time to go big and put sound in this engine.
Which type of diesel is it?
It’s an E-6
Is the factory lighting board still installed? If so one of the plastic clips holding the wire to the board may have failed, resulting in your short circuit.
So, let’s restate the problem. The loco worked fine on a DCC layout until it crossed a gap supposedly protected by an AR-1, but the AR-1 failed to match the polarity causing a short circuit.
Now the loco won’t run without shorting the layout, no matter where you place it.
So, you pulled the loco off the layout, removed the decoder and tried to run it on a stretch of DC powered track, and it still shorted.
Is this all correct?
When you tried to run the loco “in DC mode”, do you mean on a DC powered section of track and not on your DCC layout?
Have you tested the decoder to see if it works or if it is fried?
If the DC circuit board is fried, that will present a problem.
The thing is, though, it is hard for me to imagine that a faulty AR-1 would cause such problems. A dead short should shut down your DCC boos
Your restatement is correct.
I originally tried the loco in DC mode on my DCC track, which is all Digitrax BTW.
After reading your post I tried on DC track and it still shorts.
I agree that a faulty AR1 should not cause this but that is where the loco stopped working so I mentioned it. (I was also using another loco previously to trouble shoot the AR1 and it is working fine.)
The only circuit board that I am aware of, now that I researched it, is the MARS light board which also has the 8-pin connector. All clips are good and no touching wires.
I did not test the decoder. I figure if the loco is shorting without the decoder the decoder is not the problem.
Thanks for all the help guys, please keep the suggestions coming and I will keep you updated.
Do you have a multivoltmeter? If so remove the decoder, place the chassis on a separte section of track (connected to nothing else) and check continuity between each rail and each motor lead. You should have nothing when you check the motor leads with the decoder removed and no shorting pin installed. This should narrow down where the short is occuring.
Thanks. I removed the light board and connected pick ups to the motor leads and all works fine. It appears the MARS light board, photo attached, is the problem.
So I guess my question now is, does anyone know if these are still available? I’ll start calling around Monday.
Edit: Sorry, I’m having trouble attaching the photo
Check out the sticky thread at the top of the general discussion on how to post photos.
Walthers probably does not carry the original P2k Lightboards anymore. Your best bet would likely be finding an aftermarket decoder that has a mars light effect programmed into it (I believe this is a thing, I dont know for certain because my railroad did not use Mars lights).
I’d like to see that photo because I may have a replacement board.
If the only thing dead is the Mars light board, just repalce the odd dual filament bulb they used with an LED hooked to the decoder and use the decoder’s Mars light effect on that function. It looks better anyway.
Here’s the picture
Light board
Just as a possibility, here. Check the gauge of the wheel/axles. One or more may have been pushed too close together and that will short if there is no gap between the axle ends.
I have dozens of spare light boards. Like a ball of yarn, I just never threw them away, just tossed them into a box. If it turns out to be a bad board, although I don’t think it is, send me a PM and I’ll see what I can do.
Good Luck, Ed
With the decoder out, does it still dead short instantly on the rails? THe track input comes in on the lower right there and you cna see the traces go to the 9 pin socket and ONLY the 9 pin socket. So with no decoder and no DC dummy plug in place, there can be no short caused by the board. If it DOES short witht he board as pictured, no decoder, then one of the track pickup wires is probably rubbing the frame somewhere and is shorting out. If it only shorts when you plug in the decoder or if a dc dummy plug is put in, then it probbaly is something on the board. As I suspected, there is no reason to retain that board. The wires then go to the lower right are the track pickups, they go to the decoder’s red and black wires. The two wires on the upper left are the motor wires, they go to the decoder’s orange and gray. I no longer have the pictures of the P2K E unit I installed a decoder in, so I don;t recall the other wires.
Also it appears you have the blue and red crossed - look at the labels on the board, the red is connected where it says B and the blue is connected where it says R. That maight be the problem.
