Locos going only right-to-left...no reverse
Best advice yet, after stopping the video a bunch of times, and looking at the track layout. And check out the hammer laying on the track, right at the beginning.
Mike.
I’d go simple. Put the engine on a piece of track. Connect two wires to the “DC Variable” output of one power pack. With your hands, touch one wire to one rail and the other wire to the other rail with the power on say half way. If the engine moves, reverse the wires (NOT the power pack) that you’re holding on the track. If the engine moves the opposite way now, then the engine is fine. Then try the same thing after moving the reverse switch to the other setting. If the engine goes forward and then back, then the problem is the wiring on your layout.
The track over the small bridge caught my eye too. It disappears behind a can of ground foam, but the angle looks to be too great to continue on to be a reversing loop.
Hammers on the track are bad form, but it’s probably not spanning both rails or that would be a massive short.
You don’t need all that much extra track to do the test suggested, one piece is enough to see if it goes forward and backward, full throttle isn’t necessary. Stopping it on a turnout isn’t the best place to demonstrate the problem because turnouts can introduce other issues, if you are stopping on an unpowered frog, for instance.
We aren’t here to bust your chops but the track on the left side of the layout is danger close to the edge.
At some point you may find it useful to post pictures, there is a sticky thread at the top of this forum that tells you how to do that. You cannot use the clipboard function or ways that might work in other forums.
I’d like to see a picture of the side of the power pack where the wires are hooked up. If you go back to my post of yesterday (March 8) afternoon, I still think it’s possible you’ve hooked up one wire to the DC Variable and the other to the DC 12V Accessory outlet. If you’ve connected one wire the DC Variable plus outlet, and the other to the 12V Accessory (constant) negative outlet, that should produce exactly what you’re finding - engines run in one direction, but not the other direction.
Agree with stix, set up a short track separate from your layout, that eliminates all the wiring and track on the layout from the problem. Do as stix suggests as far as wiring the short section and see what happens.
Both of the loco’s what?
If stranded wire was used, one little strand could touch the wrong post (never understood why they didn’t separate the posts more on transformers). But I would go with the hammer theory.
Nah, it’s not hammertime yet. That would just short the whole thing. But the idea that one of the wires is on the fixed DC and one is on the variable DC - that would indeed render the direction switch inoperable. But still fails to get past the other symptom that physically turning the loco around without touching the direction switch also causes it to not move. It should move in the same physical direction as before, by the loco F and R designation, in reverse. That’s tliek making a 3 unit consist, if you put 2 with the short hood front and the trailing unit with the short hood facing back, all 3 will move the same direction on DC (assuming they are all wired the same). So as shown in the video - the loco will move towards the camera. If the loco is picked up and turned 180 degrees, it should still run towards the camera if the direction switch is left untouched.
AJ,
Are there any other model railroaders nearby that could come over and help in person? Where do you live (generally)? Maybe someone on this board is close enough to help.
Like I said, I have had shorts that were not enough to flip the breaker but enough to wreck havok.
That’s true. I had a problem burning out a couple of Digitrax AR-1 auto reversers in a reverse loop that had worked fine for quite a while. Eventually tracked down the problem was that when adding some feeders to the reverse loop, one wire got connected to the mainline power rather than the reverse loop connection. It wasn’t quite enough of an issue to trip the circuit breaker (and was a bigger issue going one way through the reverse loop than the other) but did a job on the auto reversers.
OK, a few things related to the various posts. There is no reverse loop – the track curves in the middle of the layout about 270 degrees, but ends at a bumper stop. The long straight stretch over the bridge might indeed be problematic – I’ve debated replacing it with a short access road and a simple bridge like the kind I’d encounter in logging country on a fishing trip. That’s neither here nor there, as I doubt it has anything to do with the problem.
Unfortunately, I do not know anybody in the area who also does model rr’ing. I think there’s a club in the area, but it’s only a rumor. I live in Maine, so things are pretty spread out. The nearest hobby shop is about 50 miles away, and the next after that 100+ The one within a reasonable distance is pretty much exclusively devoted to RC.
Today, I redid the wiring at the power pack trying all possible combinations: bupkiss. Then I did the multi-meter test, and lo, and behold, I think the problem is solved. When I tested at full power, I got +12v. When I threw the reverse switch, nothing. So, it seems to me the problem is with the switch in the power pack. I’ve had that for about 3 years, but last year circumstances forced me to put everything aside for what turned out to be about a year. I hadn’t used it in all that time. I bought an Athearn from Train Sets Only a couple of weeks ago in what I intended as an upgrade, so I dug it out. Amazingly, right out of the box it failed – it won’t even turn on! So it goes back, and I’ll get another.
Any suggestions on a good one for ~$50?
Since you already have a DCC/Sound engine, I’d suggest looking at a starter DCC system. DCC wiring is actually quite a bit simpler than DC, you don’t have to divide the track into numerous separate ‘blocks’ to run more than one engine at a time. Perhaps a Digitrax Zephyr or NCE Twin System. Each only costs about the same as two good MRC DC power packs.
BTW…you can use a double-pole/double-throw toggle switch connected between the power pack with the faulty reverse switch and the track and use it to reverse the power going to the track. Not hard to set up and only costs a few bucks.
I have a number of MRC Railpower 1370s around my layout to power signals and Tortoises. If, indeed, your power pack has a faulty directional switch, I would recommend replacing it with another 1370. These power packs are highly reliable and durable in my experience.
The 1370 can be purchased new for around $30 to $35.
Meanwhile, you ought to contact MRC and ask if the damaged 1370 can be repaired. Not worth sending it in to MRC, but tech support can tell you if it is something that you can repair yourself, if you are so inclined.
He may be able to get that switch to work by pressing down on it while sliding it back and forth a number of times. All it is is a DPDT slide switch…replacing it is not hard at all, once you get the security screws off to get inside. I said that in My first post on page one, to give that a try. They do oxidize when not used for long periods…been there done that!
I have a 70’s era MRC TechII 1500 that I only use for testing purposes, that use to do that…I just cleaned the slide contacts with CRC 2-26 and it always works…I added a DC analog meter to the top of it:
Take Care! [:D]
Frank
Anything mechanical can die, but my MRC 2500 must be 30+ years old, so they make good stuff. Used ones sell on ebay for $20 to $36
I thought I understood one of the problems to be that if you physically turned the loco 180 degrees, did not touch the reversing switch, the loco would not run. If that is still the case, part of the problem is unsolved.
DCC control costs more, it just does. For someone on a fixed income, it may be out of reach. One of our regulars just mentioned he has 600 freight cars and track radius the size of the Daytona speedway. He is absolutely happy with DC, so it’s not a must have.
We hang out in the thread Jeffrey’s Trackside Diner and discuss all sorts of off topic things. There are a couple guys in Canada, and one in the Finger Lakes, but I can’t think of anyone in Maine, offhand. Anyway you are welcome to visit us in the diner anytime.
AJ. Just to be clear, you do have the wires hooked to the two terminals on the left. The two on the right are for accessories. This is looking at the terminals straight on.
Jim
I’d love more info on basic DCC (money is an issue), something I’ve avoided as seemingly too expensive and difficult to learn. I’ll look into the two you’ve suggested, and any other learning material you can suggest.
Ditto double pole/double-throw switch – if it doesn’t involve taking things apart and/or soldering (I truly cannot solder because a medical condition makes my hands tremor too much.) I’d love to give it a try before I spend any more money on a new pack. I may not be the most dexterous person going, but I’m not afraid to attempt doing things outside of my comfort zone. I’m still VERY early in the learning curve (isn’t that half the fun of model rr’ing, the opportunity to learn new skills with a little – or a lot – education in history?)
Hi AJ, try what Frank mentioned, push down on the switch and work it back and forth, if it has some corrosion on it, it should get rid of it enough to make contact again.
Let us know if that works.
Both power packs, switch not working. That is rare. I guess it all depends on the enviroment of where they were kept.
Mike.
