Locos on both ends of a branch line run
Being a transition era modeler, I don’t spend a lot of time studying modern railroading but every once in a while I see something that catches my eye. This morning while traveling south on OH-13 from Mt. Vernon, I saw a train coming in the opposite direction. This line was at one time a major branch of the B&O that I believe ran all the way up to Sandusky but is now part of the Ohio Central which was absorbed by the Genessee and Wyoming several years ago. The branch runs from Newark, OH to serve the grain elevators in Mt. Vernon, a little over 20 miles. One train a day goes up and back on this line. I could see on the lead a bright blue loco and my first thought it was a Conrail retread but it had no lettering on the side, just a small logo under the cab that I couldn’t make out. I have seen trains on this line quite a few times in the 20 years I have lived in this area and have seen all kinds of motive power. What caught my eye today was that on the rear was what I believe was an SD-40 in Ohio Central maroon livery facing in the opposite direction. In all the years I have come across trains on this branch, I had never seen a loco on each end. There is no facility for turning a loco on the Mt. Vernon end so I assumed it was so they could have a forward facing loco on both legs of the run but this was the first time I had ever seen this done. I’m guessing there were about 8-10 grain boxcars which is the typical consist for this train so the additional motive power wasn’t needed. I’m just curious as to why they might have put a loco on either end when I had never seen that done before.
That is most likely correct. AFAIK that practice is relatively new (last decade maybe?). A diesel locomotive in neutral doesn’t really add that much weight / drag to a freight, so on some branch lines a railroad will pull a trailing engine to the end of the line, then use that one to pull the train back where it started.
The CN runs a short haul manifest daily, between Stevens Point, WI and Green Bay, WI. with a loco and an engineer on both ends.
No other crew members.
Mike.
BTW the Conrail-blue engine you saw is probably an ex-Conrail lease engine, perhaps one owned by Trans-Global Solutions. There’s an TGS ex-Pennsy SW1200 that I see every so often working the BNSF automobile yard near downtown St.Paul MN.
http://www.tgsgroup.com/services/locomotive-leasing
They have been doing it for decades. Basically its only done when locomotives are cheap. When locomotives are expensive or in short supply then hauling around an extra engine is less attractive.
On the railroad I worked for it was frowned upon because the trailing engine isn’t connected to the lead engine so there is no way to know if the wheels are slipping or the brakes have released, so they didn’t want to risk damaging the engine.
On other railroads they do it all the time.
Conrail was doing this back in the late 80’s. I worked jobs like this.
One place they used such a setup was the WNCH-99, the nightly New Haven to Danbury stone train. The train had to change direction at South Norwalk in order to get onto the Danbury branch. Then later on in Danbury, having engines on each end of the train made it much easier to pull the empties and set the loads at the consignee. Front units had the first engineer and conductor. Rear units had the second engineer and the brakeman.
The Providence & Worcester still runs this way, although they probably do it with a 3 man crew instead of 4.
It even made a way for the crew to get back without calling for transport in an incendent I saw near where I lived 25 years ago. push-pull out of Lansdale on the remaisn of the Reading Bethlehem Branch. There was some sort of company that got centerbeam flat cars near where I lived, but they usually switched when I wasn’t home. One day I am driving home and as I drive across the grade crossing before turning on the road parallel to the tracks, I glance over and see something looks a little odd. The sidine was basically rails in mud, well, when they took the north end loco and pulled the car and started shoving it back, it tipped over and fouled ont he rest of the train parked ont he main. Didn;t really come off the rails, just leaned way over. I pulled in to a nearby parkign lot to watch the action. The crew walked all around checking things out, but eventually gave up. Locked the north end loco, climbed into the south end loco, and headed back to Lansdale. Next morning, there were a couple of cranes lifting the tilted centerbeam car off the rest of the train. Had to get to work so I couldn’t stay and watch them clean it all up, but by the time I got home, it was all gone and the centerbeam car was spotted down by the industry.
It’s not grain they are serving in Mt. Vernon, its plastic pellets. They also serve International Paper on the outskirts of town and Aerial. They do have run around capability at the plastic silo, however I’m not sure if “stopping” doing that was their requirement for dual engines. They started the dual engine runs within the last 5 years (or less). Seems when the GP30 engine they usually used disapeard from the roster they started running the dual engine setup.
I’ve chased them a couple times and watched their switching and my impression was they did it because they had facing and trailing point switches to contend with as they progressed further into Mt. Vernon. I watched the crew swap from the “head end” to the “rear end” to switch out Aerial and then International Paper. Then get back into the head end power onto the plastics silo.
They then of course road the “rear end” power back home because it was then the actual head end power.
Interesting. I was always under the impression their only purpose was to serve the grain elevators in Mt. Vernon. They still have the spurs to the grain elevators. Are those still served on a seasonal basis?
Also about a rear ago I noticed a few blocks south of the grain elevators on the opposite side of a chain link fence was an old covered wooden platform. It was free standing and not next to any building. I wish I remembered which street it was off of. It appeared to be a relic of the past. Maybe a team track from the transitition era. I planned to investigate it further later on but never got around to it. Do you have any idea what that is and if it is still in use?
There are no grain elevators, just the plastic pellet silos/elevator. To be fair, I was told it was plastic pellets from a RR employee, but I can’t honestly say they were correct. However it is an industry served year round so being grain doesn’t make sense. These are the silos/elevator basically next to the B&O depot, which is also the “run around” since it connects back to the main, that I believe you are calling the spur?
The wooden platform you speak of, was it still north of the bridge? Immediately south of the silo/elevator the B&O main takes a swooping curve to the east, then back south again before immediately crossing the bridge. The southern end of the “run around” splits here, but there was also a furniture building very near here many years ago. A Coconis or something to that effect. It’s been gone for a few years (decade +?) now, but maybe the platform was there? In any event I can’t see any platform on Google Earth, but if you can pinpoint where it was I may be able to answer that question. There was much industry in Mt. Vernon at one point, so depending on the age of that platform, where it was, and if its still there or not, may indicate it was a loading platform for something in history.
Do you know if those silos have always been for plastic pellets or were they converted from grain silos? I guess I always assumed they were for grain so maybe that is why I assumed those are grain trains moving up and down that branch.
I went on Google Earth and I believe the platform I saw is in the notch of the V formed where the line splits just north of the Kokosing River bridge. From the sky it looks like the roof of a building but if it is what I think it is, there is an open platform
I am not a local to the area but I do enjoy looking at maps!
Here is a link to a Street View of the structure: https://goo.gl/maps/BEGc5WP9eCXrdHzMA
I have been looking at aerial photos and it seems the structure is not as old as it appears; it was built sometime between 1971 and 1988. I see it on the 1988 aerial photo but not 1971, or any prior.
Yes, that is the structure I remembered seeing about a year ago. That’s good research. I would have bet that the chain link fence wasn’t always between that structure and the track and that there was a spur to that platform but that’s just an educated guess.
About five years ago you couldn’t have gotten that view from Google Earth because the furniture store D94R spoke of was between the road and the tracks. I can’t remember when it was finally torn down but it’s been a few years. I wouldn’t have ever seen that platform had they not torn down that building. It was a long wooden structure right where that road makes a sharp bend to the left. The Kokosing River is just to the left of the view you posted.
There’s a remarkably crisp 1959 photo that shows your spurs in good detail. There are even a couple cars posing for the camera
!https://imgur.com/a/3WlB1HT
Note that the structure isn’t built yet.
And here’s a link to the original full size photo, but beware, it’s over 100mb
http://tas.transportation.ohio.gov/Imagery/1950s/1959/1229/1229-2-10.tif
You can see the large furniture store between Sandusky St and the railroad tracks. I don’t know when it went out of business but it was still standing until about five years ago, maybe even later.
I had a hard time navigating the large photo. In the smaller version, it appears there is a diamond where now the track just diverges. This is an ex-B&O line and just south of there the line crosses a bridge over the Kokosing River and a little bit south of the bridge it crossed the PRR line which has been converted to a bike path. The Pennsy depot still stands just east of where the two lines crossed and you can see it in a Google Earth view. I’m wondering if there was an interchange track between the two at one time and if that is forming the diamond where now there is just a diverging line.
No interchange right at the diamond, at least not in the 1959 or 1946 photos. The tracks simply crossed one another. But those two tracks did interchange just a bit further north at the B&O depot.
I’m trying to figure this out based on what I know of the area now and what I can tell from your photo. The enlarged photo shows about half the Pennsy depot at the upper left edge of the photo. That track is now a bike path and it crosses OH highway 13 and then a bridge across the Kokosing river. My guess is at some point after crossing that bridge a westbound line branched off of it back in the direction of the B&O line. Your photo shows that line going eastward to toward the left edge of the photo. There is now a tire store and a Domino’s pizza in the area where that track went. It must have been torn up a long time ago.
Penny’s trunk line through Mt. Vernon came out of Columbus, hugging OH highway 3 (The 3-C highway) for most of its route. I’d have to get out my old Altases to figure out where that line reached. The B&O line used to extend all the way up to Sandusky in northern OH but by the time I moved here it only went as far as Fredricktown and the Mt. Vernon-Fredricktown segment was abandoned by the Ohio Central about ten years ago. They were going to abandon the entire branch from Newark to Mt. Vernon until the state of Ohio ponied up some funds to improve the track. The state didn’t want all the freight from that branch being moved to trucks running up and down OH-13.
These are plastic pellet hoppers.
This place looks like it is a grain elevator. The feed mills in California get unit grain trains and loose car grain shipments year around so shipping the grain generally is not seasonsal.
If there has been any grain shipped in boxcars in the past few decades it has probably been bagged and negligible compared to covered hopper shipments.
Most of the cars I see on the trains going to Mt. Vernon are Hi-Cube plug door boxcars. I think they are 60 footers. A couple times I’ve seen tank cars in the consist. I’ve never followed the train into Mt. Vernon to see which industries get switched. In fact until you posted this Google Earth view, I wasn’t even aware there were railroad spurs in that area. It is mostly a large trucking terminal. The railroad runs between Newark and Granville roads which are where I usually drive. I’ve never had reason to drive back into that large trucking complex.
I just looked at a couple videos of that train and it did have some covered hoppers in the consist so I’m guessing the fact I see mostly boxcars is due to the time of year I usually see that train. I live outside
Utica about 3 miles from the track as the crow flies. I hear the diesel horn from my house but since there is only one train a day on that branch, I don’t often happen to be going into either Utica or Mt. Vernon when that train is running. I wasn’t even aware until I started this thread that there were other industries being served in Mt. Vernon.
Yes. Probably not technically called a run-around, but that was where they performed the operation when running single units.
As for grain or plastic, I can’t be 100% sure. I only know what the RR employee told me.
Aside from that elevator, International Paper and either Burrows Packaging or Mauser (maybe both) are served (I said Aerial earlier, wasn’t sure who all was served in that industrial park to be honest).
But, if the packaging company is getting hopper cars, I’m banking the elevators are plastic pellets. I havent chased any of the trains long enough to catch the full out and back operations but International Paper gets box cars, and then the two business south of the tracks get both hoppers and box cars. I’m guessing neither of those business’s get grain…
