Log in problem
Why is it that each new session on the internet that I go to the Rochelle/Trains.com web site I have to log in?? I even check the box that says “Remember Me”, but each time I still have to log in. Many thanks in advance.
Tim
Are you logging in on different computers? Do you log in at work and then log in at home?
Another suggestion: check your security level. Go to “tools” then “internet options” on your browser window. If you “privacy” levels are set above medium high you might want to try lowering them. If that don’t work the check your “security” and see what levels they are at. Finally, make sure that you arn’t deleting cookies frequently or be sure that your browser is set to accept cookies.
I’ve had this same problem before and it was because I had too high of security parameters and cookie blocking. Now if you’re not using a windows type browser I’m sorry I can’t tell you how to get to the internet options, but it should be something similar.
Tim
