Does anyone here have any problems with Lok-Sound decoders?
I have a Precision Craft N&W Y6b with this type of decoder and I had to send it back to them 5 months after I purchased it because of trouble with the decoder.
Runs fine now but I would like to change the chuff sound so that it will sound more realistic.
I run it on 128 speed steps and when at step 20 it sounds ok …but when I run it any faster the chuff sounds like a machine gun which I know is not very prototypical.
I had no problems whatsoever with my Reading T1. Default whistle was a multi-chime passenger one that was not approriate for my in-service unit, but the secondary whistle that was already programmed in was simialr to the Reading freight whistle, so I swapped them around. Absolutely fantastic motor control, I could let it creep around on speed step 1 anf it would take a half hour to circle my 8x12. Some have said there is a sharpness to the chuff that isn’t right - but the other night I was watchign so videos on Youtube of 2102 hauling freight on the R&N and darn if it didn;t have that loud ‘thunk’ at the end of each piston stroke. If you want ACTUAL sounds, Nick Kulp mad available a sound file for the Loksound decoder that includes actually recordings from 2101 when it was AFT 1. This is an advantage the Loksound decoders have over Tsunami - don’t like the sounds, you can change them! They also have connections for a shuff cam so they can by synchronized by actual wheel rotation if you can fit the parts in.
I purchased the Precision Craft California Zephyr A-B-A locomotive set with LokSound when Factory Direct Trains had them on closeout.
Something shorted out and melted the decoder in the lead A unit after a few short operating sessions. I contacted FDT and they sent a replacement along with a pre-paid UPS return label. So far, the replacement has been okay. FDT’s customer service is the best I have ever experienced.
However, the horn is extremely weak and cannot be made louder. I’ve been told that the only way to change the horn or make it louder is to purchase a LokProgrammer. Since this is the only LokSound equipped engine I have, it’s not worth the cost of the programmer.
As has been stated by other users several times on these forums, LokSound decoders have the smoothest motor control available, but their sounds are very weak and can be changed only with the LokProgrammer.
I had the whistle volume problem with my T1, but that’s because out of the box engine chuffs were set on max volume and the whistle was set to 50%. The bell was also set to full on. I put the bell and chuffs to 50% and the whistle to 100% and there was plenty of volume for me. No Loksound programmer needed, just set a few CV’s. If you actually want to put a different whistle/horn sound in, then you need the programmer.
A Loksound decoder came in my Trix Mike. While I don’t care for the fixed whistle very much, I think the chuff is outstanding. It’s “throatier” than the QSI chuff and sounds much more realistic above speed step 010. It also crawls very nicely. [:)][tup]
On the contrary! I have LokSound decoders in a pair of 12 year old Proto 1000 GP7’s and they are great! I can MU them and run at step 1 for coupling or switching. Just one of them will pull 25 cars up my 2,2% 33"r. helix with no problem. If I go 30 or more cars I need both units. If it wasn’t for the fact that I want to try the diesel Tsunami in some F3’sI would definitely go with more Lokies! signed: A happy hogger!
Keep in mind that’s a Loksound 2.0, not Loksound 3.5 that PCM used, and that you buy now. They kept the awesome motor drive and fixed up the sounds quite a bit. The whistle on the 3.5 is even playable to some extent with those DCC systems that support that. (At least any Digitrax with a DT400, and the PowerCab. ProCab with the last update I think too)
LokSound decoders that are factory installed are different beasts than the aftermarket ones. The aftermarket ones are full featured while the factory installed ones are lacking some features…
