I’m currently in the market for a new transformer. I have a Lionel CW-80 and it works fine, but I’m buying some more track and engines and am looking for something with a bit more power. I have 2 MTH Railking Steamers, 1 with just a whistle and 1 with the original protosounds I, er, Santa, bought on ebay, and a Lionel Hogwarts Express engine. I don’t really plan on beefing up my motive power roster, but I’m buying some more fastrack and switches.
I am considering a Lionel KW, but I’ve read of people having issues with postwar transformers and modern day sounds, so I wanted t get some info first. I’m open to anything, so any suggestions and input are welcome to this recently out of the closet (a joke, I’ve been hiding my love of model railroading haha) railroader.
Hope to hear from you guys soon, and happy new year!
Just because you say you have MTH engines I would have a tendency to look into maybe one of theres whether it be a Z-1000 or Z-4000 ( I think I’m not very knowledgeable on MTH stuff) as I have heard a couple of times its better to have a MTH transformer if you have MTH engines especially if you have that Proto 1 system
The BW-80 will only put out 5 amps, even if connected to 8 or 10 180 watt bricks.
The BW-80 and CW-80 controllers actually have very robust 7-8 amp transformers powering them already anyway. The circuitry only uses a portion(up to 5 amps) of what is actually available.
To play it safe then I’ll just look for a new transformer lol. I’m thinking about bidding on a MRC 270 watt dual train transformer with a remote controller on ebay, can anyone tell me about this? I’m still strongly considering a refurbished KW. The prices are reasonable and I like the look of it. Plus it’s not too huge, having seen them in real life.
I really like the Z1000 myself. It is simple, reliable, and powerful to sum things up. I use Z1000 bricks to power my TIUs, and they work great for that. The breakers used in the Z1000 bricks also trip quickly, which is nice.
If I did decide to go with the KW, there is something I can place between the transformer and track to help trip the breaker in the event of a derailment so as not to fry the electronics on my locos. What is this?
what type of track are you running reason I ask if its tubalar I have some old new in package K-line protection lockon that is Bi-directional Duplexed protector
What you should put between your transformer and the track (or even inside your locomotives) is a transient-voltage suppressor (TVS). This will limit the voltage that your locomotive sees to a safe level of a few dozen volts.
It will not however trip your circuit breaker, nor does it need to, to protect your locomotives. The circuit breaker protects the wiring and the transformer. It is not meant to protect electronics, which will not draw excessive current until after the damage has already been done.
It is my understanding that there never was a CW-80 “with a brick.” What you must be talking about is the look-alike controller-with-brick, correctly called the BW-80 which was only produced for a year or two and discontinued about the time the all-in-one-case CW-80 was introduced.
This is not meant to be picky-picky, but does suggest that if one searches for information with the “Search our Community” feature one will be better served if one calls things by their proper names.
As far as protective devices are concerned, there are a whole range of built-in and add-on mechanisms: from circuit-breakers to “fold-back circuits” to fuses to TVS diodes, etc.
This variety of devices reflects the different protective functions of the different items – which can be confusing indeed! As a general rule, if you are going to run modern trains with modern electronics, you will not only need something to guard against overcurrents (“short-circuits”) but, in addition, somethingelse to protect from voltage spikes. Ignore this at the risk of permanently damaging your equipment. The anti-spike protection can be added absurdly inexpensively.
Bob “lionelsoni” and others have posted extensively on this subject. A search should yield a LOT.
Hvae patience you can get a Z 4000 at a reasonable price. I fried my Proto 1 premiere with my ZW PW transformer. I am speaking from experience here just be patient and hold out for a Z 4000 they will run everything you put on the track.
I’ve run a ton of Lionel and MTH locomotives with a KW and ZW, no problems at all. If you’re going to use a PW transformer with modern electronic locomotives, I suggest a TVS and a fast-blow fuse in the track connection.
I’m more than likely going to go with the KW. Now, for the TVS, I’m sure I’ll be able to find one, so thats not an issue. How exactly would I go about “installing one”?
