Looking for an obscure Athearn RTR part
Hello all,
Recently I purchased a used Athearn RTR C44-9W off of eBay. It was advertised as broken, but I was able to fix all of its problems with little effort using parts I already had at my disposal (and in turn, managed to acquire the locomotive for much cheaper than a fully-functional one)…
Well, I’ve fixed all of its ailments, save one… One of the clips on the top of the trucks that mounts the truck to the frame was broken on arrival… Without this clip, there’s nothing to hold the truck solid in its proper place, which causes it to shift around front and back and side to side, which in turn causes the driveshaft to slip out…
Does anyone know where I can find this part? I’ve looked all over and can’t seem to find it…
Well immediately after making my post, I’ve been able to identify the part I need… Turns out it’s called a “pivot clip”, part number ATH60515… It’s towards the bottom right of this exploded view…
http://www.athearn.com/ProdInfo/Files/RTR_SD40_Parts.pdf
Now the fun question is still this- where do I find this part?
Order the part from Athearn. You can also try ebay.
Yoi may be able to order it from Athearn.They have limited amount of parts listed online. If its not online you can call them and get parts that way.
Ron High
There is a phone number right on the sheet to call for missing or broken parts.
Matt,
Click on link:
http://www.athearn.com/Products/Default.aspx?ProdID=ATH40053
Take Care! [:D]
Frank
EDIT: Talking about two different animals. Call them…it’s best. Should be able to reach them through link above.
