Anyone have any ideas where I can obtain the following part???
I model several Canadian diesels, specifiocally CN, CP, ONR and VIA FP-7a units. I am in need of the roof mounted frame with bell assembly used on these diesels. None of the American detail part manufacturers have such a thing available
Does anyone know if some other manufacturer has this Canadian part in their product line, and if so from whom can I obtain a number of them???
You might try http://www.miniaturesbyeric.com/index.htm He specializes in Candian detail parts. Several of the roof mount bells are right on the first H0 parts page.
Note: I have been buying parts from him close to 20 years and there have been periods where shipping and email responses have been a bit slow, but I have always gotten what I ordered . The castings are mostly brass and some are resin and the quality ranges from very good to excellent.
RailFlyer Prototypes also has a multilayer PE frame with a plastic bolt plate & a very nice machined brass bell that can be built in almost any configuration. Google them & check out their other pix of parts. If you want scale accuracy give them a serious look. I have also used many from Walthers (including the above), but the RailFlyer version is the nicest looking.
Icicle breakers are easy to make using Detail Associates brass strip and wire:
Bend the strips to the proper shape and solder them together where required. Bend mounting tabs at the base of each piece, drill appropriately and solder a short length of wire in each hole. Trim the top of the wire to represent a bolt head, and insert the lower portions into holes drilled in suitable locations in the loco’s roof. These can be bent-over inside the shell, then ca’ed in place.
