I am looking for the washer and drive washer in the motor for the banjo signal. Does any one know where I might find these?? Stan Orr does not have the drive washer.
Most sources for parts have the drive washer listed, including Stan Orr. The adhesive washer is no where to be found, and you may need to get some thin double-sided adhesive tape and cut out your own.
Larry
I’m pretty sure if you order the drive washer from the Train Tender (ttender.com), it comes with double sided tape already installed on it. It’s just peel and stick.
J White
I just use regular Elmer’s white glue to secure the drive washers on bajo signals, beacons, and searchlight cars. It is much easier to work with than the adhesive washers.
