I am looking for a specific sound of which I will try to describe. I want to see if I can program it into my AC4400’s using Digitrax SDH104K1A+FN04K1 COMBO decoder.
While I was watching a youtube video I beleive the AC4400 was sitting still and it almost sounded like a brake or air release of some kind…
It was a very short spitting sound or clicking sound and happened about every 2 or 3 seconds.
I’m not sure what I’m looking for nor can I find the video I was looking at !
Any thoughts would be appreciated![um] (In case of spitting).
Usually that is the air pump cutting out. Check the manual for your decoder. Digitrax has the manual. All the air pumps I have ever worked with do that.
I believe that what you’re describing is the automatic condensation drain valve that the big GE’s are equipped with.
It sounds almost like a large electrical arc or zapping noise.
From what I understand, it doesn’t so much limit pressure in the reservoir (the cutoff on the compressor does that), but rather it just eliminates the need for someone to periodically perform a manual process to drain the condensation.
