My estimate, even though the low camera angle works against me, is that the radius is near 200’. Two-hundred feet X 12"/foot comes to 2400". Converting down to 1/87 gives 27", which I think is a closer approximation than 18"
Those look like White Pass and Yukon locomotives. Their website suggests the tightest curve is 16 degrees (as the prototype measures curves). According to this source, that translates to more like a 50" radius curve in HO.
Here’s a complete table of degrees to inches for most of the scales: http://www.urbaneagle.com/data/deg-curve.txt 16 degrees is 49.5 inches in HO. The Maryland and Pennsylvania had a 20 degree curve on their mainline which is 39.7 inches in HO.
The CN doubletrack mainline at Paris ON goes over a high rail bridge and then curves to the southeast towards Brantford. the curve there is just enough to make for a loud squeal of protest from the cars. So much fun prototypically----I wonder just how much of a curve one needs to do that–
I am speaking in the normal MR terms for curves: radius or radii. As for where I got it I do not know. Have you read my post on POWER VS. DUMMY LOCO.? Midnight Railroader asked how I knew all this information at such a young age (now 13. Its my Birthday). I am near the bottom at http://cs.trains.com/trccs/forums/p/148416/1644898.aspx#1644898
Given the lateral play in our model trains, I suspect that you would be better off pinching a curve a little bit. Of course you might get a derailment before you get enough squeal to hear. [(-D]
Maybe we could get Soundtraxx to do a sound decoder for freight and passenger cars.
Don Adams’s fine On3 layout Dublin Branch of the D&RGW has something like a 380-degree curve at the end of a peninsula. He has a sound unit there. Flick a switch and you hear the sound of wheels rubbing against rail. It is a nice effect.
