The RPM in idle can be the same as the RPM in run 1. Moveing the throttle from idle to notch 1 enguages the juice to the traction motors. But the RPM settings for each notch can vary.
On modern (current production) units, this is done by rebooting the control module then adjusting the settings accordingly. BUT do not try this without a member of your railroads local “flying squad” to lead you through this process the first time-or else! 2. No. 3. Yes. 4. All of them! NS is the most prominent, but they all do this at one time, or another
Why do they change the Idle RPM? And do they usually increase it or decrease it from default?
You say all RR’s do it at some point. Can you think of a couple of first class RR’s that do what I described in the first post (have the idle running at same RPM as run1 on EMD’s) ?
I can’t really answer the question in that format. But I’ll try to explain it the way I understand it. I’m sure Randy S. could answer this as he is a experienced loco mechanic. I am not and this is just from observation. So till then…
The way the MU throttle works is similar to digital to analog conversion. There are 4 lines on the MU cable that connect to the governor of each locomotive. Each of those four connections and there corresponding governor valve settings (A,B,C,D) has a ‘weight’ to it. The combination of these lines / valves will determine the total throttle. If A is the least significant valve then it will have the least effect. If D is the most significant valve it will have the most effect. I don’t know the RPM numbers so I’ll use nice round numbers to try to explain. Say A has a factor of 1, B-2, C-4 and D-8. If valve A is on then you would be at say run 1. Then if you advanced the throttle to 2 then A would close and B would open. The ‘weight’ af A alone would determine the RPM and can be adjusted by some means. The same would go for the B valve alone in run 2. But for a factor of 3 a combination of the A valve and B valve together would determine the RPM and would be dependant on what the individual settings of each of the A and B valves is. Then the next notch would be 4 and the C valve with the factor of 4 would be on by itself and its setting alone would determine the RPM. Then for the next notch, 5, the combination of the C and A valves (with weights of 4 and 1 for a total of 5) settings would determine the RPM. And so on and so on…
I hope Randy Stahl jumps in here–he’s the guy that ought to know.
I was under the impression that “default”, as you call it, was the same for all EMD 645s, and is the same for each and every engine type out there. It isn’t changed–you m.u. three locomotives of the same builder, and they’ll all sound the same, because they’re running at the same RPM in each throttle session.
And, yes, Run 1 is the same RPM as normal Idle.
Low Idle is something different–engines will slow to a “low idle” setting after a certain length of time in idle, or when the reverser is centered. Saves a bit of fuel.
Most, if not all, microprocessor-controlled 710 engines have a low “neutral-idle” speed, where the throttle is in idle and the reverser is in neutral. SP’s 645-powered GP40M-2 units rebuilt by MK Rail do this as well.
No, on older locomotives with the woodward PGR governers , low idle was accomplished by energizing the A and the D solenoids in the governer. When the reverser handle is thrown in forward or reverse the engine goes into NORMAL idle ( around 360-400 rpm) . The locomotives that have this feature also have a NIR relay ( normal idle relay ) to activate when the reverser relays move.
There is another feature sometimes found on older locomotives called an LIP (low idle panel) . This system has a temperature sensor somplace that decides when and if the engine will run in low idle or not.
On newer locomotives (microprocessor) , the computer determines the best RPM for the conditions, some EMD’s and GE’s will sometimes only have 4-5 different engine speeds, this is very true on GE’s to stop excessive smoking.
