lubricating a torpedo with a pullmor
Hey guys, to put it mildly I’m not good at this so here is the question. I need to lubricate my torpedo with a pullmor motor and the manual says to use the lubricating points at the ampeture. The pictures aren’t very precise and I do not want to put oil in the wrong spot. Can anyone explain precisely where to put the oil? Much thanks. Jim
by ampeture I’m assuming you mean armature, you lubricate it on the end of the armature shaft and there should be an oil fill hole on top. There’s more too, but it involves taking it apart and lubricating the bearings inside which might be more than you want to get in to.
you are correct on all points. thanks much. Jim
