M-PRCB
I live in Ames, Iowa. When can I see M-PRCB come through, and are 1995 and one or both CNWs still assigned to it. Does it stop over in Boone? If so, when
Thanks
I’ve been away from the action for nearly two weeks, so I can’t tell you whether the 1995 and the two surviving Dash 9s are still on MPRCB/MCBPR. The westbound would probably go through Ames after dark. If the units are still assigned to these trains, they’d come through on a cycle of once every four days–sometimes longer.
MPRCB-29 had the 1995-8701-8646 trio on it- it and it’s counterpart MCBPR stop in Boone to change crews. The same 3 units most likely will make up the consist of the MCBPR-31- which as I last recall left Council Bluffs in the early afternoon for Proviso- as for the time when it would pass Ames depends on how fluid the main line is and how quick they can get the train through the Boone crew change.
Lately, the MPRCB (westbound train) arrives Boone around midnight, give or take a few hours. Instead of a connecting crew being called out, its held and called out about mid-morning.
I heard the 1995 yarding it’s train Thursday night. I saw the 1995 and the two CNWs at Council Bluffs Friday night/early Saturday morning.
The MCBPR (eastbound) is usually called thru.
Jeff
Hey Jeff, have you gotten the chance to operate 1995 yet?
No, not yet. The only heritage unit I’ve run is the MP (UP 1982). I just get to see them in passing.
Back when they first assigned the Salt Lake Olympic units and the United way engine to the rotation, I had the first MCBPR with them out of Council Bluffs. It was a Friday and I was surprised at the lack of fans out taking pictures. I found out why when we met the UP 1995 on the QPRNP. Everyone was out chasing it.
Jeff
