I know that this has been covered (indirectly) before but I can’t locate it… I also searched for pics with little success… must be using the wrong search words…
At long last I have enough M3 Bradleys available to load several cars…
So I need to know if I stick with 60’ flats or can use 89’ intermodal flats (same as for Humvees)?
How many M3 to a car? I think two on a 60’ and three on an 89’… I think that this would work for both lngth and weight… Am i right please?
DoD maintains a fleet of six axled flat cars for this specific use, 3 M3’s fit per car, I believe these are in the area of 70 feet, I see these flatcars frequently here in Southern California, they can accomidate 2 M2 Abrams tanks as well .
Typically 2 M3’s are carried when a traditional 89 foot flat is used, and 3 Humvess are common on 60 foot flatcars.
Also - don’t forget to chain and block your Bradley’s in place. They are supposed to travel well secured to their flatcars. The DoD has very specific instructions on how this is done.
The M1s almost always use the approximately 570 DODX 40000 series 68’ 140 ton 6 axle flats. They are also extra wide for the M1s. They could of course easily accommodate the Bradleys, it’s just a matter of available 40,000 series. I’ve had to scratch build mine. At one point I had hoped some mfg would make them (Andersly did for a while for a kit).
Here’s an excerpt from a somewhat dated DOD document on some of it.
There are approximately 1,500 flat cars in the total DODX fleet. These DODX flat cars are unevenly divided into four car series:
Would you mind shareing how you built your 40000 series cars? I have been looking for some heavy DoD flats to model, I am a little disappointed there aren’t any avalible. I don’t think I will be modeling a full military unit train, but a few cars could make for some interesting mixed loads.
