Magnetraction
this little thought’s been bugging the heck outta me, even though I think I already know the answer, based on how these questions usually go. Lionel Trains have had magnetraction since 1950, but of course, not all trains were equipped with it. So, I just figured it’d be kinda neat to ask the foolhearty question, “can a train without Magnetraction, be fitted with it?”
Now hold your horses just a moment! I know that there’s a huge ammount of variables to consider, this likely depends on what the locomotive is, when it was made, and of course, it’s almost definitely not worth the trouble, vursus just buying a loco that already has the feature. But how can you learn, if you don’t ask? I mean, consider the 2026, with it‘s fat center drivers, which folks have often speculated were designed so, to help take advantage of the use of magnetraction. Could some clever individual make that “what could have been” scenario a reality?
And the 726RR- essentially a 736 without Magnetraction. If an idividual REALLY wanted, could they convert it to Magnetraction?
Just a question to prompt some brain picking, speculation, and maybe bring with it a little knowledge which wasn’t known to me before.
That said, my hunch is that maybe there’s a few models you could convert, with some extensive work, but for the most part you can’t.
What do other people have to say on the matter?
If I remember correctly, the actual magnatraction part is the axle, with that said if the axle would fit the hole for the axle I would say yes you can. But like you said the 726RR isn’t, but if you did find a axle with manatraction ability, would you have to change the wheels also as they be made of a different alloy that isn’t magnetic. You do have a good question here, but not sure of all the elements to do so. And to switch axles and wheels isn’t really that big of a job, especially if you have the press and correct dies.
I actually read up on this a little, and at least for the 736, but probably for other locos, the axle has to be made of stainless steel- it cannot be made of a magnetizable metal!
I would assume that the wheels do not need replacing, since I doubt Lionel would need to change the alloy on the wheels during the korean war. Wheels are not made of different metals for magnetraction and non-magnetraction locos, as far as I can tell. Once they introduced magnetraction, it seems like it was all sintered iron drivers, magnetraction or no magnetraction. So the only parts you would need to replace, would be the axles. And of course, you would need to magnetize the rolling chassis. As far as I know, there were three ways of doing this. Magnets that went around the axle, magnetic axles, and magnets that would sit in the frame, near the axles. I have examples of at least two of these in my possetion. I seem to recall, the 736 utilized the latter of these methods, but I may be incorrect.
If a retro-fit with Magne-Traction is possible I’m not sure it’d be really worth the trouble. You’d have to find the requisite parts, then have the tools necessary such as the wheel press and dies as rrtraincollector mentioned.
And then there’s the track you’re running on. I use MTH Realtracks which are nickle-silver. Magne-Traction won’t work on them.
Some of my post-wars have Magne-Traction, some don’t. It doesn’t make any difference to me. My 736 and 2056 are such bruisers they’ll pull tree stumps out of the ground, Magne-Traction or not.
To add magnetraction to an original postwar 726RR one would have to:
pull all the wheels
Add the magnetraction keeper plates to the sides of the chassis
Swap all the axle bearings
Swap all the axles
Add the magnets.
To add magnetraction to an original postwar 726 (pre-1950)
  • would be a custom job involving all of the above, plus
    milling the chassis to take the keeper plates and magnets.
    replacing all the drive wheels
It could be done by a clever machinest.
IMHO, neither is cost effective.
Thanks for all the replies!
I think this is worth restating though:
I stated in the start of this thread, that I was certain it would not be cost effective, or practical. I’m just curious about what is physically possible, and what isn’t.
definitely some interesting thoughts. I figured the original 726 wouldn’t be anywhere near doable, since it’s almost a completely different design from the 736/726RR.
also, before anyone asks, no, I was not planning to attempt this kind of modification, nor do I own a 726RR.
I do own a 2026, but the ammount of work that would take, plus the skills neccesary, kinda limits things to being tabled until I have machining skills, and proper quartering jigs, and so forth.
I assume you have a 1952 2026, which has sintered iron wheels.
It’s construction is almost completely different than a 726RR
They cannot be converted because the motor’s metal sideframes are magnetic. The magnetraction version of that motor assembly has aluminum (nonmagnetic) side frames.
Most folks would do the conversion by swapping motors.
When making repairs or putting together one of those locomotives from parts, a lot of people do not pay any attention to whether they are using the correct motor assembly. It was made in non-magenetraction, magnetration, and tire traction models. The last locomotive to use it had a two position e-unit, so the field was double wound. This was a tire traction version. Don’t know whether any tire traction locos had three position e-units.
It is said some loss occurs when you pull magnetic drivers. Lionel magnitized the axle after it was assembled to the drivers. A much easier way would be to buy a used chassis and switch cabs.
I was thinking a 1947-49 726 Berkshire. They are very similar in construction to those made from 1950 and on.
I would agree, that converting an original postwar Berkshire from 1946 would be quite a challenge. It’s construction is very different.
Yes the very early ones would not interchange.
As the saying goes, “If it ain’t broke, don’t fix it!”
Lionel did magnetraction in three different ways:
o Simple magnetized ferrous axles
o Simple stainless-steel axles, with separate magnets’ poles located near wheels or motor sideframes
o Magnets encased in outsized stainless-steel axles
In all cases, the design had to avoid paths of permeable material, like iron or steel, from side to side, that would short the magnetic circuit, which is why magnetration motors had aluminum sideframes and cross-members.
When I could no longer quiet the bearings of my already heavily modified Korean War 2026, I simply replaced the motor with one from a 2037 and thus acquired magnetraction.
Would you (or anyone) have a list of the Lionel engines that were made with Magnetraction? As always, thanks.
I’m not sure of a master list of what had Magne-Traction, but you can try this site…
www.tandem-associates.com/index.htm
Select “Lionel Index” or “Identify Your Lionel Trains” and go from there. You’ll see a menu, select “Identify Postwar” and you’ll be presented with a list of various products. If you have a particular engine in mind look for that engine by model number, it will tell you if it was produced with Magne-Traction. Or not.
VERY handy site!
Thanks.
You’re welcome! Hope it’s useful to you.
Rather than going through the rather complex (and expensive) procedure of installing stainless steel axles, etc., if you have steel wheels, couldn’t you just “magnetize” them by rubbing a magnet on the area that contacts the track? I remember as a kid “magnetizing” all kinds of stuff by rubbing it on a magnet (especially screwdrivers). Shouldn’t be hard to set up a fixture where you could spin the wheel and hold a magnet against the area that contacts the track. Doesn’t have to be held so hard it grinds the surface of the wheel. Just enough to maintain contact until the wheel is magnetized. And as a kid we had pretty weak magnets. Nowadays you can buy some super-powerful ones. So the magnetic transfer would be quite good. Granted, it wouldn’t be the same as factory magnetraction, but even that gets weak over time.
Another possible and easier option, would be to Crazy Glue a magnet TO the axle. Axle doesn’t have to be stainless steel to transfer the magnet abilities. Just carbon steel. Actually, stainless steel isn’t all that magnetic because of the numerous alloys included in it’s construction. Pure steel is much more magnetic.
Just some thoughts that popped into my head. [;)]
The reason for using stainless steel is that a common variety of it is not magnetic at all. The idea is to make the magnetic flux pass through the wheels on one side, into the steel rails, through the steel ties across to the other side, and back to the magnet through the wieels on the other side. Steel axles will defeat this concept by providing an alternate flux path between the magnet’s poles–a magnetic short circuit.
Lionel’s first try at magnetraction tried to solve this problem by combining functions: The axle was the magnet. The problem with this idea was that the best material that they had was soft iron, which made a not-very-permanent magnet.
I dunno, all that passing through and moving around seems like it would lose a lot of power in the process. Why not just magnetize the wheels themselves? And I don’t know what “common stainless steel” is, but the stainless steel in my Smith and Wesson guns is quite magnetic. Just having “the axle as the magnet” makes for a very small magnet. If you attached one of the super-powerful magnets available today to the axle, I would think it would be a heck of a lot more effective. If you could find a tubular-shaped magnet, one that reached from wheel hub to wheel hub, slot it so it would slip around the axle, and attach it with crazy glue, you would have a magnetrction that put the original version to shame. Or alternatively, a cylindrical magent with a hole drilled through the center that slides onto the axle. Like the ones here:
https://www.kjmagnetics.com/products.asp?cat=16
Considering the ratings for these magnets, they should be way more powerful than anything Lionel ever installed. I am in the process of restoring a bunch of #50 Gang Cars. I may just experiment on one and see if I can give it effective magnetraction. [8D][Y]
Stainless steels are alloys of iron with various other elements, including at least 10.5 percent chromium. There are many varieties, in three families of alloys: Ferritic and martensitic stainless steels are magnetic; austenitic stainless steel, by far the most common type, is not. Austenitic stainless steel is the kind Lionel used, because of its non-magnetic character. The steel in your guns is obviously one of the other types.
(I’m afraid magnets don’t work the way you think they do.)
