Hi!
Well, it took a long time, but I finally have the main level plywood in place, and the surface is ready for track laying. The layout is in an 11x15 room, HO, code 100 track, and two levels. The lower level (subject of previous postings) is connected by a winding 2 % grade, and ends up with 6 storage/staging tracks - two for passenger trains, 4 for freight.
This is a “replacement” layout of one I built in the early '90s, with two main differences. The earlier one had a lot of tunnels and rockwork (which really cramped mainline railroading), and was wired for DC (which was more complicated than necessary). This layout will be a platform for trains and structures, with minimal bridges and no tunnels (except the one leading to the lower level). However, there may be a couple of additional bridges added, and I’ll “jigsaw” the plywood as needed to make the cuts.
The layout is also being wired for DCC, which I find to be simpler, but of course more “finicky” than DC. The chosen system is a Digitrax Super Chief with two boosters, two controllers, and two PSX4 circuit breaker setups - allowing for 8 power sectors.
Once the roadbed, track, and wiring are in place, I’ll do a complete testing and then begin placing structures and putting in scenery. I’ll start on the outside perimeters and work my way in towards the center. Lastly, I’ll paint the faces of the benchwork flat black, and put an edging on the top to cover the ends of the plywood.
The pictures try to “walk you around the room”, and I have to add that they make the room look much smaller than actual size. Oh, yes, there is a dreaded duckunder (40 inches wide), but its necessary to maximize the layout surface. And frankly, if this 65 year old, 225# guy can quickly get under it, then that’s fine by me!
