Main Street Particulars
Say you have a small town (not a big city) on your layout,
how wide, in inches, did you make it’s main street?
Did you try to be prototypical or fudge a little to make things fit the space?
Room for parking on both sides or only one? Or, none at all?
Did you install/paint center lines, traffic lanes, parking spots etc and how?
Since all towns and villages are a little different, I don’t think there is an exact answer for you.
I plan to start by taking two vehicles placing them side by side with a reasonable space between them as they meet on the road. Parallel parking takes up less layout space, so will pull one up to the curb and leave space between the parked car and those traveling past. If I want parking both sides, same on other side of road. Roads and parking can eat up a lot of layout space. Most comments I have seen when this has been discussed before seem to tend toward narrower scale streets than they actually are in the 1:1 world.
More modern cities tend to have had better traffic planning thus streets tend to be wider. But, I have seen old villages where houses are set back 100’ each side of the road, leaving plenty of room for road expansion, beautiful front lawns and keeping the noise of the traffic away from the house… (Those were the days.)
Someone may chime in with some of the technical data to give you a better idea, but most seem to end up with a “what looks good” width.
Good luck,
Richard
I just went with something that looked right to my eye. The white stripes are rattle can paint. On of these days I’ll get the ballast down.
You asked for a dimension in inches - but never mentioned scale. Two inches is a footpath in O scale, a driveway in S, an alley in HO, Wall Street in N and a boulevard in Z.
Street width is a regional thing. In the Northeast, Main Street could be quite narrow. In recently-developed towns in the wide open spaces Main Street may have four traffic lanes and diagonal parking.
Your best bet is to get a photo (or several) of an appropriate prototype, then eyeball it from there.
One thing is sure. You’re almost guaranteed to find that the real thing is wider than you would like it to be.
So, how wide is MY main street? Sorry, but I don’t know. Most of it is virtual, in my operating aisle.
Chuck (Modeling Central Japan in September, 1964 - with roads that are two ruts in the mud)
Pardon the not mentioning the scale, please… it’s HO.
I decided to cut out a template from white paper 3 1/2 inches wide and try it. This gives me two traffic lanes and parking on one side. I photographed it, brought it into Photoshop, colored the paper a concrete-ish color and painted some white lines. Looks about right to me and leaves me much needed space for the park on the opposite side of the street and for the structures on the ends of same street.
Jarrell,
I know you know the answer to that…
It is what you make it-------- > and there is always a prototype somewhere.
Some streets only allow parking on one side and they tend to be narrower.
A number of years back, I pulled a load into Worcester, Mass. Many of you will be familiar with that area.
I was surprised to find that the streets were so narrow that on one side they allowed cars to park half way on the sidewalk so that there would be clearance for traffic to meet each other on the street.
Also there was a Fire Hall that had it’s overhead doors right at the sidewalk, so they would have to completely block the street when leaving or backing in.
Different places > > > different faces…
And by the way, what you have there looks great as everything you do does…
Johnboy out…
I am currently working to recreate an urban scene where three major roadways meet to create a triangular city block between the three roads. I created my roads using lanes around 9 to 9 1/2 scale feet wide so as not to use up too much real estate. The main road through town (along the edge of the layout aisle) is a four lane divided road with a single railroad track running along a center median. Even with the compressed lane width and no curbside parking, this one roadway is 7 inches wide curb to curb! A second four lane road meets the first at about a 30 degree angle and runs between the aisle and the backdrop along this same shallow 30 degree angle. This road does not include a center median or curbside parking and is still 5 inches wide curb to curb. I wanted curbside parking along the third roadway so I gave it only two traffic lanes and further compressed the parallel parking lane width. This road worked out to about 4 3/4 inches wide curb to curb with parking on both sides. It crosses the other two roads at angles of about 75 degrees. This means that this third road runs nearly perpendicular to the aisle and backdrop.
I am building multiple structures along the far side of the first roadway (the near curb of this roadway is defined by the edge of the layout) and multiple structures on both sides of the other two roads. Where I don’t have enough room for curbside parking, I have included small driveways between a few structures and added “Parking In Rear” to my building signs. Although my scene will include a combination of both street and rear of building parking, I only need to model two parking lot areas while other rear of building parking will simply be implied. A tougher problem has been how to terminate such large roadways at the backdrop. I realize that I can use forced perspective to aid in the illusion but even this will leave fairly wide gaps in the background scenery toward the centers of the ro
Jarrell,
I believe 3-1/2" is what I have for the main drag through my small town. There is no parking, per say - except at the diner, gas station, and freight depot, which is more than a parking space length from the road.
I was going to use Blair Line wood grade crossings. Their 2 lane crossings measure 3.56 inches (for HO), so my roads will probably a little over 3 inches. Don’t know what I am going to do about parking yet.
Ken
I went with 5" wide for the main street. The 5" allows for two lanes of traffic along with parallel parking on both sides.
I went with 3 1/2" for other roads.
The roads are cut from .010 Evergreen styrene sheets. I air brush them Floquil grimy black.
Road stripes are 3M pin striping. I use 1/16" thick stripes. 71001 for double stripes, and 70101 for all other striping. It’s nice that they offer double white for my late 1950s era layout. Unfortunately they do not offer double yellow for modern era layouts.
Can’t tell you if these are prototypical road dimensions, but the sizes looked good to my eye without overpowering the layout with streets.
One detail I think that really adds to a street scene are Hi-Tech Details parking meters.
Here’s the most recent photo of my developing city streets, this shows the 5" streets:
An older photo. This shows parallel parking and the 5" main street transitioning to 3 1/2":
Here are 3 1/2" roads through a residential section:
I saw your post this morning, but had to get my notebook from ther layout in the cellar, also trip to the dump and post office, lunch and a couple hours of work on the layout - so here it is 5PM with my answer for you, or at least how I do it. I model in HO scale
For city streets I plan 24 foot wide for the 2 way travel lanes; but could reduce to 20 feet on side streets. Parallel parking spaces are 8 ft wide and 20 feet long; perpendicular spaces (like in the depot parking lot) are 9 ft wide and 16 ft long. I model the 50s, so on a modern layout the spaces could be 1 to 2 feet larger to acommodate those big SUVs and pickups. Sidewalks are 10 ft wide for big sidewalks or 5 ft for smaller. This would be 2 concrete squares wide for a busy city shopping street and 1 square wide for side streets, residential, and town sidewalks. They could be reduced to 8 ft and 4 ft, if space is a problem.
A couple of examples:
Greenvale Junction, a town with a depot. Depot St., parallel to the edge of the layout, is modeled half width with the rest imagined off the edge. Main St, perpenducular to the edge, is modeled full width with parking on one side up to the tracks. The sidewalks are 5 ft wide.
Central St in Sheepscott is a city street with both travel lanes and one side of parking modeled. The other side parking and buildings are imagined. The sidewalks are 10 ft wide. This is an in progress photo with some buildings as cardboard mockups or added using Photoshop as a planning tool and to give me an idea of what it may look like when finished. Still in progress with 4 or 5 more buildings to go. The street is colored using Photoshop, it and the sidewalks were tan Durhams Water Putty color when the picture was taken. I have since painted and added parking spaces
[IMG]http://i139.photobucket.com/albums/q301/ggpaine/Model%20Railroad/Sheepscot/Buil
This was something I was working on yesterday. I immediately abandoned inches and worked in scale feet.
My town section consists of one major street, three slightly smaller parallel streets (retail and service area) connected to the main street by a third road size, and then a residential area. Blocks are bisected by alleys.
Main St: 40 feet with 10 foot sidewalks on either side.
Side Sts: 36 feet with 10 foot sidewalks on either side
Connection St: 32 feet with 10 foot sidewalk on one side and five foot on the other (this side faces the tracks)
Residential Sts: 28 feet sidewalks TBD probably 5 feet
Alley: 15 feet
These streets are rather broad for a model but look right for what I’m trying to accomplish. My town has a 19" x 7 1/2’ area so I can spread out a bit and not run out of space.
well, if it’s of any concern. I live near {and was raised in} a small town that happens to also be the county seat, and of Victorian 1800s in nature.
The Main and Front street {along the river’s edge} BOTH have 2 lanes and parallel parking on either side. On some houses, the old granite ‘carriage step’ is still there, along with a horse tie-up ring on a granite post next to the old {and getting replaced} slate sidewalks. All of which were in place at the Victorian carriage days!.
~So take two cars and place side by side and allow for two cars parked on either side too. that will determine your width. IF you have the room for 4 lanes in your town. That will give you the inches you need for the cars of your era.
~In my little town on my little {3.5’ x 5.1’ HO } layout, I had no room for 4 lanes, so i settled for two. So I guess you could say I fudged. I allowed for a "municipal parking lot’ {small also}, such as our little county seat also has between buildings or behind the stores in 1:1.
~ already answered the parking on both sides issue. GO with one if you only have room for one sided parking.
~ Hadn’t gotten to painting any lines or such yet. But, if I did, I would make faded lines when I get the chance…though in the “residential districts” near town center, on Front and Main streets, there ARE NO lines at all. Just plain street. Not sure why, but I’d bet no lines were painted on the brick road substructure {the once “paved” roads once} either.
That’s my town and I’m sticking to it!
[8-|]
This sounds great. I think I’ve seen the fun foam you’re talking about, I believe the ones I saw were black in color. What do you use to paint your center lines etc.? Are you building sidewalks also and if so what thickness are they? I’m not familiar with the foam putty, is it easy to use and do you have to sand it a little to smooth it?
Good luck with the problem of the roads meeting the backdrops, that’s always a challenge.
[quote user=“hornblower”]
Thanks Tom, I guess I’ll be about right if I go with 4 1/2 inches for two lanes and parking on one side.
Matt, that looks great! I hope mine come out near this good. Thank you for the tip on the parking meters, they do add that realistic touch, don’t they. Any tips on putting down the pin stripping and getting it to stay down?
I see you have a park across the street also. I want to do one of those and have been thinking about a statue on a pedestal in the park. Maybe an O scale figure (I’m HO) of a soldier or something of the sort.
I like the clock too!
^sigh^ so many ideas, so little time.
[quote user=“Southwest Chief”]
Ken, I hadn’t thought of that, I have some of those grade crossing too!
David, they look about right to me too. I guess you masked off everything and rattle canned the stripes?
Thanks John boy. My brother in law was a trucker, he told me some harrowing tales about delivering on narrow city streets!
Thanks Jarrell.
The striping is actually pretty easy to work with.
It comes on a carrier strip. I lay this down where I want the stripes. Then simply pull up on the carrier strip and the stripes are installed. So far it’s worked great. And it’s staying down nicely too.
Here’s a photo of the park:
I’m not sure who made the clock, maybe Brawa? It came green and I painted it gloss black. It’s lighted too.
Eek, I still have to ballast the track. So much left to do [:S]
