That depends on what kind of a view you would like to capture. If you would like to have something close to the perspective of a HO scale figure watching the train go by, I´d suggest to use a telephoto lens equalling about 75mm lens in the good old 35mm photography.
I’d guess that either would work, as long as your camera will automatically re-focus as the train gets nearer.
Telephoto and wide-angle lenses both distort the image, or at least parts of it.
Since you’re not wasting any film, as you would in the pre-digital age, why not simply shoot a few clips using various settings, and see which gives you the results that you want?
If you are using a DSLR with a full frame sensor try using a 90mm or 100mm Macro lens. You just need to ensure that you have adequate lighting to enable you to stop down the lens for a broad depth of field even though your focal point is narrow.
Normal or wide angle. Telephoto lens have less depth of field and they foreshorten the image. You can tell when a picture is taken with a tele lens, the foreshortening effect is a dead giveaway. I used a low end point-n-shoot on a tripod to make some decent videos of moving HO trains. A DSLR should work even better.
I use a zoom to frame the picture instead of me moving closer or farther back.
Using an adjustable telephoto lens and being far away allows you to reduce the zoom, keeping the train in frame. Being able to slowly (i.e. manually) change the zoom would be helpful.
