Making Dirt/gravel roads
Hi all,
I am having difficulty getting my gravel roads to look right. I tried doing them like ballasting track. lay the gravel then glue it down, but it doesn’t look like a dry gravel road when i finish.Any ideas?
I use a base coat of brushed on chocolate color paint and then a top coat of Rustoleum texture paint.
I tried using very fine ballast but it was still too big.
I know exactly what you are talking about. In my opinion the problem with most model gravel roads is that if you try to use separate stones they are as a rule way too big, way bigger than true road gravel is. Gravel in a gravel pit is one thing – more like ballast in size – but they crush it more than that to use on roads or alleys. There it tends to range in size from pea-size to maybe an inch or so, and that is incredibly tiny in HO. I mean, imagne the finger tip or thumb size of an HO scale figure! So we are in essence trying to make rocks look like pebbles and stones.
The other problem in my experience is that people want visitors to see the ruts so they make the ruts too deep in both dirt and gravel roads, without giving thought to whether anything other than an army vehicle could actually drive through.
If you could magically reduce a true gravel road to model railroad size I think we’d be surprised by how relatively smooth it looks. Not glossy smooth, not poured concrete smooth, but smooth.
On my layout I have a macadam street – where they laid down hot tar and then small pebbles, with sometimes a roller pressing them in but often letting the traffic do that part of the job, and for that I used the reverse side of a roof shingle – basically a textured but flat and even surface, and painted it appropriately to show more of the black tar where the wheel traffic is the highest. On the edges and center line, where pebbles tended to gather and NOT get ground into the tar by passing traffic, I used the very smallest “limestone” ballast I could find, a Highball product intended for Z scale. It is almost dust like. The effect looks good to the naked eye, but a digital photo I took shows that even that ballast is a bit big. But thus far I am pleased.
The plastic tha
Use the real thing,
http://www.sceneryexpress.com/prodinfo.asp?number=SE0403
http://www.sceneryexpress.com/prodinfo.asp?number=SE0413
I have used the medium and the fine, the fine texture is actually dusts up when I apply it with a spoon. The medium is the same with scattering of rocks and some larger boulders. I use it as a base for ground cover, then add other items later, but it could easily be use to define a gravel road over another texture.
On my last layout this worked well: http://www.pacificcoastairlinerr.com/scenery/clods/
Some excellent advice here already
I’ve used a couple of different materials for mine. First one was made with artists modelling compound
Before painting [compound still wet]
Fine sand and sieved dust from a bag of ballast was sprinkled onto the paste.
Second one was made with water putty, sand and ballast dust
Mike
Thanks everyone.
Mike, that’s the effect I’m after, looks great.
Phoebe vet, have you got a photo so I can see how it looks?
Alan J
Alan if you decide to use water putty, I used Agnew’s from Bunnings. Come to think of it, I seem to remember buying artists modelling compound from there too, but it has to be a big Bunnings.
Mike
You may want to look at Joe Fugate’s video on Scenery and Bridges Vol. 4 Part 1 in which he gives a very good description on how to build a very realistic dirt/gravel road. The other information in this video on other aspects of scenery is well worth the purchase price.
Bob
Alan:
I’ll get a picture when I get a chance.
Alan:
Here’s a dirt parking lot.
