Making Something New Look Old...
I recently purchased a couple of the Walthers Merchants Row kits. They look like simple to assemble kits that should make nice-looking buildings but I want them to look old and dilapadated. I want to depict an old, run down section of town with some of the businesses that would eventually settle there. You know, bars, liquor stores, etc.
I’ll likely have some boarded up windows, some lousy looking paint and some faded signs. Does anyone else have any suggestions to make something new look old?
Thanks!
dlm
For brick buildings, I like to first give the brick a wash with india ink in alcohol solution (2 teaspoonfuls in 1 pint 70% isopropyl), then apply morter like Robert’s Brick Morter (not sure if this stuff is still available - when it dries you just wipe away the excess, you can leave more or less to give a chalky surface to represent older brick). After painting the other details (window frames etc.) give another wash overall of the alcohol stain. Cut out old signs - sand the paper as thin as you can then apply to the brick with white glue. You can lightly sand the surface, apply some alcohol stain etc. to make the sign look really faded. As a final touch I like to do a light drybrush with some antique white to bring out highlights like window frames.
I like these kits. In particular, I like the deep grooving between the bricks, which makes it easier to get a good mortar effect between them.
For an older look, select a couple of dull primer colors like rust brown or rust red. On these kits, the shops look like they are in different buildings joined together, so I do a lot of paint-mask-paint to get that separation. Some Dul-Coat or other flat spray helps, too.
I like making and using decals. I just have an inkjet printer. It’s simple to download an image and print it on inkjet decal paper, then let it dry and seal it so the ink doesn’t run. I also seal decals after they’re set.
Some kits come with big windows. I find these are great for rudimentary interior details. Again, I use my printer for wall panels and floors, and put walls in to separate the shops and upstairs rooms, as some won’t be illuminated.
GO with DullCote. The clear spray will remove the shiny plastic look. Afterward, do some weathering. You might consider looking at realistic images of buildings to see how to replicate reality. Mixing different techniques also is a great weathering techniques.
You can add some details such as a gutter hanging off, lots of wires and various disconnected electric meters etc.
Also add barrels and general junk in the rear or side if that can be seen.
For painting, in addition to weathering you can have some old colors showing through the paint.
It’s easy. Given my modeling skills, ALL my buildings come out looking old and decrepit
Hello All,
I kitbashed two (2) Walther’s “Northern Light and Power Powerhouse” kits into one large building.
Despite being the same kits the colors of the batches of plastic used for the brick walls didn’t match.
I used “rattle can” red primer for a uniform color to the wall panels.
The primer also has a matt finish so no DullCote necessary.
One modeler was advised to paint all his structures flat black and then paint them his color(s) of choice.
The reasoning for this was even if the color(s) didn’t cover opaquely the flat black background would not be a distraction.
Another suggestion was to use salt between the base coat and the final coat. (This technique is also used in horizontal concrete to impress a pattern in the finished concrete.)
Salt is sprinkled over the base coat in an uneven fashion- -even in clumps. For HO table salt works well for this effect.
A finish coat/color is then applied and allowed to dry.
Then the salt is brushed off to reveal the base coat underneath in an uneven manner- -like peeling paint/rust spots.
Ink washes and weathering powders then can be applied for further effect.
Hope this helps.
Thanks for the salt tip. I’ve done something similar with rubber cement brushed on either real clapboard walls or the plastic ones. It can result in an excellent peeling paint surface.
