G’day folks.
I recently tried to fight off the temptation to adopt yet another example of a unique locomotive. The New York Central T-3b won [:-^]
NYC_T3_Alco-side by Edmund, on Flickr
The seller made it clear that there was “trouble” with the spring couplings [his words] but I figured this to be just one more challenge for re-powering or adapting a better drive system.
Here’s a look at the overall arrangement:
NYC_T3_Alco-works by Edmund, on Flickr
On one end, away from the brushes, something seems to be interfering with the worm shaft in the truck gearcases. One of the spring belts is not as snug as the other on the brush-end.
NYC_T3_Alco_1 by Edmund, on Flickr
You can see the ends of the worms which engage the brass axle gears in this view:
NYC_T3_Alco by Edmund, on Flickr
The sheaves have knurling in the groove to improve grip. Replacing these spring belts with an O ring is out as I would have to cut the frame and gearcase. There is structural work in the way. The spring belts can be threaded through and around the worm shaft, then joined.
I discovered the spring belt was a somewhat common drive technique
