Mantua 2-6-6-2 logger
Has any one done a decoder install on one of these ?
From a Google search.
You did not mention sound so this should do.
http://www.tcsdcc.com/Customer_Content/Installation_Pictures/HO_Scale/Mantua/2-6-6-2_T/2-6-6-2_T.html
More info.
http://cs.trains.com/mrr/f/88/p/219947/2430189.aspx
I did a pre order when they were first released, it took 2½ years to arrive. It came DCC ready and ran OK with a Digitrax DH123P. It is the noisiest locomotive I’ve ever owned, nothing worked to get rid of all the mechanism noise. It spends most of it’s time parked in or next to the roundhouse.
Mel
Sad to hear Mel
Hoping the later model runs better
but from one of the links Rich posted it looks like this loco also has shorting problems
but it appears they can be fixed
Thanks for the links Rich
Hope i can fix the shorting problems that the poster talks about
Looks like there’s enough room for a Keep alive above the motor
If the decoder will fit in the cab standing up straight
Then i can use the Coal/Oil bunker for the speaker
If not then i could notch out the walkway behind the side tank and use a sugar cube
I did Google the Loco and did see a reference to shorting but not sure I can find it right now.
