Manual Throws - Best Way To Make Remote, Brass Tubing/Piano Wire?
I am an N scaler finally building the mini Southern railway I’ve always wanted, having a blast. I now have all modules designed, & have built 1/2 my benchwork.
My question - I am using manual ground throws mounted at layout edge, & attaching to turnouts via piano wire strung through brass tubing, a technique I saw in MRR years ago.
Is this still the best/most reliable way? Or is there a better way? Using Caboose ground throws, any better switches around?
Any help GREATLY appreciated, thank you
Lee
That is a wonderful method to throw turnouts. At the club I was in before I moved, we used that method for turnouts that were a couple feet from the front of the layout. For turnouts that were closer, we used just wire and those brackets that pivot to make 90 degree turns. (I can’t think of their real name.) For turnouts more than two feet away, we used Tortoises. To throw the turnouts, we used inexpesive cam lock and key sets.
Years ago, I saw a layout in which the turnouts were operated by the use of automobile choke control cables. They worked very well though I have no idea how they were set up.
To piggyback on that, lawnmower throttle control cables (cheap this time of year) also work well. Those 90 degree pivots can be hand fasioned, or you can use some of those that are made for radio control uses. Matter of fact, you might be able to use their control rods too.
Humpyard levers are the same mechanism, but have a great look as well. They cost more but add something to the control panel.
Art,
Silly me, but I am a noob [%-)] What are humpyard levers and what do they look like?
Brian
Here is the web site.
http://www.humpyard.com/
Here is my application
A company in australia makes a good control unit.There web site is www.modratec.com.
Southernman - these gizmos are very easy to make - and best of all inexpensive. Use 14/2 wire with piano wire or florists’s wire. You can make them as long as you like, and they do accept a curve. They work like a charm especially with peco switches.
Let me if you need any more info
Not only does Modratec offer a control set up, they also offer:
  1. What they call Wire In Tube (WIT) which is just what this post started off asking about.
  2. A software package for planning the control system for safe working (preventing trains running into each other.) A FREE download!!
Have a look. I am sure you will find it interesting.
Here is an example of the control panel.
I have used the humpyard throws on my layout. They are vary adaptable and easy to install and use.
Thanks SO much everyone, some great suggestions here. Gonna experiment, maybe order a humpyard to fool around with, then make my decision, thing is I already have the Caboose throws, tubing, & wire, we’ll see.
I’ll be sure & post pics when I get into it
Thanks again
Lee
For those of using humpyard levers product. Are they sturdy? Do they have contacts for power routing (lets say 5vdc for leds??)
The humpyards are sturdy for me. The Gkids have not broken any. I read that they could be used to route power, but I have not tried that.
Somebody somewhere said he used R/C airplane control cables. Probably more expensive than choke cables.
Somebody else uses thin dowel rods in metal tubes.
And somebody else uses bicycle shift / brake cables as they’re already in a tube. You just have to figure out how to anchor them.
I use ordinary brass doorbolts, some 0.040 music wire, and some zero percent stretch 30 lb fishing line to make a home-made turnout throw for less than $4 each.
(click to enlarge)
To see more, click here.
Follow-up question guys - if I use humpyards, I will be installing over 2.5" foam OVER baseboard, can I sturdy the turnout end of the humpyard cable with a clamp into the foam? Maybe if I glue in a slab of 1" wood, & then clamp the cable? Will it hold it?
Thanks again
Lee
Great suggestions, and Joe, that doorbolt system is brilliant! Thanks.
Mike
I was always able to find some wood close enough to anchor them. For caboose turnouts I glued a piece of wood, painted to simulate a wooden platform to spike them to. I would think that would work for humpyard as well.
