Manual turnout switch throws
I notice on alot of layouts that they have the maual switch throws connected to the turnouts. Is this what is used to operate the turnout? Or are they there just for looks?
Greg
There are several kinds.
Caboose brand ground throws are very durable and are typically mounted right next to the turnout. They work well, but they are not the most realistic looking.
A better bet for manual controls is using something that is mounted to the fascia of the layout and driven with wires and/or cables.
Most of the big layouts I’ve operated on have manual throws–the Caboose ones like the one one’s mentioned. If your goal is to have a highly detailed layout accurate in every way, then theses throws are not for you. However, if you are interested in realistic operations, there is no easier system and you are usually too busy to notice that they are a little larger than the prototype.
The really neat thing is if you don’t have to train people where the switches are and how to use them.
I use the caboose throws for my manual turnouts, and I learned a trick to minimize their maximalist appearance…
I cut out the foam where it will go, and recess a small block of homasote into the ground about a 1/4" below the sub roadbed level. Then I use a track nail to reach from the actuator to the throw bar. It works really well to camouflage the throw. A little paint and some scenery, and you hardly see it.
Lee
I use Details West for appearance. I have a push - pull -device for the motion of turnout and switchstand. My video working switch stand
9 MB and a how to.
Wolfgang
A variation I like for good looking remote manual control is Humpyard levers from Humpyard Purveyers. Google it to see what I like (No I do not work for them).
very nice , i like your site a lot !
No hits on google. But if you google for “Hump Yard Purveyance” instead, you will find them.
http://www.humpyard.com/
Between $6.50 and $8 per lever (depending in quantity bought), but looks pretty sharp!
Smile,
Stein
Thank you for your fee back.
Greg
