Marx Semaphore
I’ll be receiving a Marx semaphore shortly. It’s coming without any accessories. Will it work on the Lionel O27 track with a Lionel Contactor or would I have to get the Marx attachments? As always, many thanks.
It will work just fine with a Lionel contactor. It will probably work more reliably with an insulated rail (“control rail”). Marx used a copper channel that fit over an outside rail and was insulated from the outside rail, to get the same effect as a control rail but a rougher ride for the train, since the channel made a sort of speed bump.
Bob: You always come through. Once again, thanks so much.
agreed. I use Lionel contacters with my Marx stuff.
