I have a Marx motor that I have wedged into an old AF clockwork enging body. The motor runs well at start up, but as it runs it slows down. When I touch the brass tube that hold the brushes, it is very hot. The brushes are probably original, but I have cleaned everything and see no sparks coming from the brushes and commutator. I do see sparks coming form the side rods as they brush the wheels. Could that be adding to the heat build up?
not always. My 671 had a short in the wire going to the pickup, that would only happen once in a while. Had me baffled until I saw a tip in Ray Plummers column IIRC.
