I’m working on an MDC 4-6-0 and I am at the point where I can paint it. I already have the headlight, marker lights and firebox lighting in place. I’m going to prime the model with cheap gray solvent based auto primer. I am going to use MicroScale Micro Mask to mask the lights.
The final colours will be done with acrylic paints. Micro Mask cannot be used with acrylic paints but what I am wondering is will the primer prevent the acrylic paints from messing up the Micro Mask?
I know I should do a test first, but before I go to all that trouble I was wondering if anyone had any experience with Micro Mask in a situation like this.
Not sure Dave as i never try Micro Mask before. When i built model airplanes and need to mask off the cockpit glass i use Vallejo Liquid Mask.
The bottle does say
Used to reserve areas which are to remain unpainted, especially in airbrush techniques, but also with watercolours and temperas. Liquid Mask forms a protective film on the area which the artists does not want to paint. Once the work is dry, liquid mask is rubbed off with an eraser or piece of cloth, revealing unpainted area.##
Another alternative masking technique is to use one of those hole punches with the rotary heads that allows different size holes. Or use a set of punches that come in a set and is used for cutting plugs out of wood. Punch out what you need from your preferred masking tape. The drawback is the limited range of hole sizes.
I’m with the masking tape proponents - faster, easier, and cheaper. I’d be worried that the liquid masking would accidently end up somewhere that it wasn’t required. If the tape covers a bit of the surrounding area, touch-up with a brush is easy.
I have used rubber cement as a mask in the past. Just make sure you do a test first. Rubber cement just rolls off when you rub your thumb over it. I have never had a bad experience using it, however, there is always a first time.[C):-)]
I’ve used little balls of stick-tac in a pinch. Roll up a little ball and flatten it onto the lens until the lens is fully covered. Picks right off when done.
