max. grade drop per foot.
I am rebuilding my layout, and this time, shall be building a six by six foot area for a helix facility. A part of that will be to drop from the first level down to a staging storage area which will be located just under the layout. I figured that this should both save money, and make a staging yard readily accessable from the front, where (hopefully) I will be spending most of my time while operating. THis having been said, I am at odd ends as to what would make an equitable precent of rise/drop. If you have experienced this kind of construction/approach, I would like to hear from you.
yellowjacket EF-3
Since you didn’t mention scale, I’ll give this in units that, if built with laminated 1/4" plywood subroadbed (total 1/2" thickness) and 1/4" roadbed, plus 3/32" rail+tie depth and slightly over 4" ‘Mighty Hand of God,’ clearance. Single track, curve radius, 34 inches, huge for N scale, not over-generous for HO. With a total rise of 5"/turn, the grade would be 2.35%, uncompensated. The reach-in clearance of 4" can’t be reduced much for N scale, since it’s based on a 1:1 scale human hand.
I’m running very short trains on much steeper grades in my much tighter helices, so those aren’t very good examples of what to expect.
