my understanding is the the nominal brake ration (NBR) defines the maximum brake force for rolling stock as 10% of the car weight (yes, it would be different for empty and loaded)
is 10% correct as the maximum brake force of the independent brake on the locomotive?
Many of the variables have to be taken into consideration.
A locomotive will pretty much act like a loaded freight car. Weather the brake cylinder pressure is applied using the independent or automatic brake application has no bearing. Brake cylinder pressure will result in the same force.
as i tried to explain, i’m trying to figure out if there is a typical value for the max brake force as a % of loco weight, like it is for rolling stock, the NBR
Here’s the thing: the figures for cars already presuppose solid wheels. I suspect much of the discussion regarding diesel locomotives (and newer electrics) would involve the same. You can brake these until they turn bright blue and expect reasonable safety.
That’s not at all the case for steam locomotives or power with separate tires. The effect is amplified if heating due to driver brakes is limited and more dependence is placed on leading and trailing trucks.
A great deal of the braking effort to slow down the great mass of, say, a modern 4-8-4 has to be provided by a trailing consist. There are videos of 3751 on test that show rakes of spine flats or other lightweight intermodal equipment used for this purpose.
Although I still can’t find a shred of evidence that it was ‘legal’ in the ETTs, when test speeds of GG1s in Metroliner service began exceeding 110mph it became very clear that Amfleet consists could not and did not do their fair share of decelerating those heavy locomotives… and the required tread braking started driver tires coming loose. I assure you this is NEVER a good thing operationally, and a much larger factor of safety than that provided for one-piece forged or cast wheels, including multiwear down on the wear limit, ought to be provided for any such power…
