MDC loco remotor
Has anyone had any luck dropping a new motor into Model Die Cast 2-6-0 oldtime Mogul. There is not much room, the original motor is 10mm (13/32) wide X 20mm tall. It is really a good looking, good sized engine that I would like to keep it on the active roster. Thanks, John
I’m afraid that you are in the wrong section. Try posting in “Model Railroading.” I’m sure you will get an answer there.
