MDC two-truck Shay
Here is a pic of my MDC 2-truck Shay.As I recall this kit was a bear and I had to de-assemble and re-assemble it until I got it to run right.Now she runs great!
I believe Frank Wright explained the running problem to me. The mechanism has a “gear loop” in it.
Gears inside the loco turn the wheels, which turn the exterior gears which run the valve gear.
He recommended removing all but one of the 4 exterior gears, or filing the teeth down on three of them, to remove the loop.
Unfortunately, the axle gears are split on mine, so I haven’t been able to test the solution yet.
If you’rs runs ok now, then even better.
Our MDC 2-truck Shay was RTR for DC. When we went to install decoder for DCC, we found other problems. We installed a NWSL regearing kit. Now it is a tough runner.
http://www.youtube.com/watch?v=oU6rK8Hy17M
Thought that you might enjoy this.
Sue
As i recall(I made the kit in’84) I had to shorten some of the squared brass tubing that connected to the Shay engine.(note:This conclusion was arrived at over many frustrating assembly sessions).Now she runs just great i did not find it necessary to alter the main gears in the main differential.
An entire book was written on how to get one of these Shay kits to run properly by using parts from North West Short Line and other manufacturers. When I calculated the cost of the parts, they were going to be more than the original kit.
Then MDC came out with the RTR version, so I bought it. I still have an unassembled kit that I will probably never attempt to use.
Even so, the Bachmann Spectrum 3-truck Shay is a much better engine.
Our Bachmann 3-Truck Shay has never run as well as the regeared MDC 2-Truck Shay. The Bachmann is quieter, but the MDC will pull more.
I know that is contrary to other responses, but we found the NWSL kit worth the investment.
Sue
I had a 3 truck, it was missing parts, or I couldnt get the 3 truck to run right, so I 2 truckered it.
Just careful construction, tweaking there, here, it ran like a dream, no extra parts whatever.
It ran near continuous on the HOn3 club loop during open houses. Only prob I had was the rotating shaft on the rear was a tad short, so on some ubquitious moment it would slip out.
I sold it but bought another to build -right-
Ours has a surging type of lurching on the down hill as slow speeds. It is very annoying. Bachmann sent us new parts, but the thing still does it.
Sue
But so did the prototype [:D]
But that is a Bachmann and mine is MDC different animals!
The Bachman 3 truck is a pretty locomotive, and I’d buy one again in a heartbeat.
But it does surge on downhills.
It is a bit noisy.
Most of all, the railroad we model only had one Shay and it was a two truck.
Even though I love it, the Bachman is an anomaly on our layout, some sort of an unexplained visitor from another railroad.
My problem is the layout of the NWSL website.
I go there and wander around, not really knowing where I am,what I’m looking at, or whether the parts I’m looking at are the right ones or the wrong ones needed to regear the MDC two truck Shay.
I’m pretty sure it takes two sets of gears, the axle gears, and the bullnose gear housing.
Sometimes I even think I know the right model numbers to order.
But so far, the idea of transferring the money to my internet checking account, ordering the parts, anticipating their arrival for howrever many weeks or days it takes them to arrive, and then finding out they are thee wrong ones, or worse, not finding out they are wrong and screwing up the only limited availability two truck Shay we have has stopped me from actually placing the order.
It wuld be very helpful for me if someone who had actually done the repairs and was sure of the part catalog numbers could confirm what I only guess so far.
Sue, loved your vid of your shay-looks great running at a correct low speed. But I have to admit, what blew me away was your background music choice-The Osborne Bros. with Red Allen from 1957! (I had to make sure my computer “jukebox” hadn’t suddenly taken on a life of it’s own since I have that album loaded in.) Once again, great vid!
Built an MDC the first year they came out–can’t remember how long ago. Little devil took me almost two weeks, and it ‘ground’ like all Heck when I started breaking it in, but the noise went away–or at least became bearable. Still have it. Still grinds like crazy, but that little devil will pull like crazy at 5smph. I’ve got a Bachmann Spectrum, and I like it and it’s smooth and quiet, but the little, noisy MDC still outpulls it.
Neat loco, that little MDC. I like it. It was a BEAR to build, though, LOL!
Jeffers,
I spoke with my husband. He agreed with you that the website was not easy to navigate. There is an article on the MDC on their website that you should read. He replaced the brass bullgear, and believes the other item was the partial regear kit. They also sent a hard copy of the article with the kits.
It will take me a few days to look up the invoice if you are interested. my husband gave me the part numbers and I called NWSL in Seattle. The parts arrived in a couple days.
Sue
Jeffers, I think the best idea is to simply call NWSL and get one of their gurus on the line, explain what you want to do, and he/she will make sure the correct parts come your way. They may even be able to explain (or better, have instructions) if you need them.
Last time I had a friend
Why was it necessary to buy a re-gearing kit?I admit that this kit was a bear but after I got her running she pulls and runs well.As for the noise.I kinda like it,and the sight of the crankshaft and running gear spinning like mad is cool.Visitors reallly like it and have many questions about it.All in all one of my fave locos!
Philo, my axle gears are split, either one out of two trucks, or else three out of foru axles, can’t remember which. They just spin on the axle. One axle turning isn’t enough to move the loco with the others dragging, so new gears are a must.
People who know the engine pretty well, who described the gear loop to me suggested I replace the bullgear too. Quality and longevity issue IIRC, and possible side benefit of quieter operation.
Gear Jammer, I’ll just call NWSL, no need for you to go digging. I’d thought of that before and if memory serves, they were shut down over the holidays, and I never picked up the thread again after normal business hours resumed.
Thanks for the offer though.
Which gear has split?
