Does anybody know a supplier for metal railings (photo etched or soldered brass)?
I need to replace the plastic railings on an HO tug boat which were ruined trying to bend & glue in place. These are simple welded railings with 2 rails. I need about 24".
K&S is a company that deals with all sorts of spring steel and brass rod. A good LHS usually has a display stand carrying an assortment of what you need.
What i do for railing is take some telephone wire, strip off the insulation, and solder it to K&S brass rod. (I don’t know the dimentions of the brass rod right off hand) I build a jig on a scrap piece of wood of balsa or bass wood strips to hold the stantions straight while I’m soldering the wire to them…chuck
