I’m kitbashing a few of structures and I want to give them metal roofing. I’ve seen a few corrugated aluminum products out there and I’m going to use it on a couple of the structures. However, I’m looking to create some variety and I’m wondering if anyone can recommend alternative metals and methods? I’m not against styrene sheets, I just prefer not to use it.
Thanks in advance for any and all advice. I’m starting to get the hang of kitbashing. What a blast!
Materials: Collect a few soda cans to slice into sheets. Stop by your local building supply store (Home Depot/Lowe’s) pick up a roll of copper roof flashing. Thinnest possible.
Corrugated roofing: go to Michael’s and in the paper craft section, get a rolling paper crimper, makes very good corrugated roof.
Standing Seam roof: If you have LOTS of TIME and have a metal brake (a good vise and metal shears will do) you can make a “standing seam” roof. Standing seam construction with vise: cut material into strips 1 ¼ wide: right side, in vise make a 90 degree 1/8th inch fold, then complete the fold onto itself, then make the 90 degree fold along the edge of the first fold. On the left side a simple 90-degree fold will finish the job. Now when you glue it up and crimp the standing seam, you’ve got a good looking roof. This can be done as a single piece as opposed to strips. Every one inch make the folds to have the ridge sticking up about 1/8 inch.
Flat metal roof: Cut the material into rectangles about one inch by four inches (2’x8’ at 1:24). Glue into position, and apply extremely small drops or lines of asphalt tar to simulate roof glue.
Cutting the metal: A good pair of metal shears - good. A good solid paper cutter - better.
I second that motion. (hic)[:-,] I prefer the thinner Bud Lite can as they are easier to cut after consumption. Caution, must use wire mesh gloves, bud lite cans cut deeper and longer.
Friends… have just come across this article and am interested in replacing the roof of an hotel I made last year. Due to the inclement weather we get here in the NE of England the roof, made of scale shingles cut from lollypop sticks, has lifted. (This is in the summer)Three coats of Thomson waterproof sealer and silicone failed to hold it together.Having read the article I need to know if:- (a) a plywood base was used to fasten the metal sheets to and (b) what type of adhesive was used or other fastenings.
I usually use 1/4" thick hardibacker tile board for most of my buildings. It has held up well over the years though years of ground contact may cause it to delaminate (not an issue for roofs). I have used it as a substrate for plastic veneers sheets (asphalt and tile roofs), tread tape (for rolled roofing) and aluminum as pictured on the station above.
The hardibacker was spray painted with a couple of coats prior to the roof finish.
Loctite PowerGrab was used to glue on plastic veneers Urethane construction adhesive (liquid nails) or silicone was used for aluminum.
If you decide to go wood shingles I would invest in cedar ones available from several sources (Smith Pond Junction, Garden Texture, etc.). I use Phenoseal Vinyl Adhesive Caulk (found in the caulk aisle) translucent for cedar shingles. Works great and holds up well outdoors.
Other possible roof substrates you can use are coroplast (corrugated plastic board) or 1/4" plexiglass.
Alan: I use “open beam construction”. I run 3/8" square beams where the seams of the metal roofing will joint. I use the Marine grade Loctite adhesive; it works very well for wood, metal, plastic glazing, rubbers and vinyl’s. I rarely use any substrate under my roofing material, course, I’m cheap that way.
I was fortunate to visit with Yogi @ the East Coast show this week end @ York. He had some great idea’s. The best example was just tin. Where can you get plain tin? I 'm using Coke, Moose Head, Guinness for the roof. should be interesting. I think some were it was said you should put the metal in the oven to change it’s properties? Any comments on that?
Some of your local, smaller newspapers still sell their aluminum printing plates for under a buck a sheet, they should work fine. We were on vacation and I picked up the local paper and saw they had the sheets for sale, I went down and got a dozen. Ink washes off with soap and water, one side is unused. Might look around. I plan to use a sheet on making a car, once I get around to it. Sheets are about 20x30".
I’ve used aluminum from soda cans, run through a paper crimper. I’ve also embossed some by hand to look like the flattened tin cans used as shingles on many old desert buildings. Now I mostly use .010" thick brass sheet, which you can get from several online sources. I usually get it from www.smallparts.com
I use redwood bender board from my local home improvement store under my coke can metal roofing. It is cheap and stands up well. Goop and small nails or H.O. railroad spikes hold it down. My friend puts his cans in his gas bar-b-q to to soften it. It comes out with an interesting “aged” look. Bob J.
I’ve been using gutter flashing as metal roofs for about six months. It’s about four inches on a side, some is six. Some has one side longer than the other, in case you’d like to have a lean to or bump out on one side of your building.
It’s galvanized, and takes paint very easily. I’ve made three trolley stop roofs with it, and some small motel buildings, too.
If you’d like a picture or two of these buildings, drop me a line. Showing them here seems very complicated!
Since nobody else did… Putting the the soda/beer can metal in the oven draws the temper and makes it a lot softer. It will turn brown with a bit of purple shading. Sorta looks weathered. Lot easier on the crimper to.
I notice the crimper is available in the narrow and wide sizes, at several popular stores.
Hmmm, warehouses, grain elevators, ect. That is a lot of “pop cans”. Using the paper crimper is going to be hard on the fingers. Sooooo…I’m making the steel version of the paper crimper. Should be able to crank a roll of roof flashing through it in a matter of minutes. [:)] Of course I’ll post a pic of it when done. Was never one to do anything half way.
Yogi has a home made heavy duty crimper on his page. I doubt you will be able to crimp aluminum flashing. Its just too thick for that purpose. Yogi gets rolls of thinner stuff (thicker than soda cans though) that works great.
