Probably not. What’s to say there is only one broken knuckle? If you send the air to rest rest of the train, it will most likely roll away when they kick off, and the train line will separate again, leaving you back where you started. Or maybe worse, as the limited amount of charging time might mean less than effective brake application and dumping the air may not stop the unattached portion.
Maybe installing more of these might help. Some of the newer FBOXs have them from the factory.
No. The Some Are To Concerned About A Train Which When You See A Train Over And Over That Would Be Good Since Around Your Town There Would Be More Business Which When There Is Less Train Someone Who Could Think Can Someone Get This Train Out Of Here Could Lose A Career Because A Railroad Could Be Much Reliable To More Than One Customer.
So Once You See A Train Around A Town You Are A Resident Of And Head To Your Work Just Think That This Train Here Could Make Thousands For The Business You Work In The Next Few Hours.
