Here is a comparison of a 1.2mm, 1.5 volt lamp with a SMT LED. The lamp voltage is 1.55 volts and 9.4ma. Very little heat. The lamps come from www.led-switch.com.
The LED is a SMT LED from Litchfield Station. 12.4 volts DC, 1 k resistor, 12.24ma.
You can also get many flavors of LEDs from Jameco (www.jameco.com) and Digikey (www.digikey.com). 1206 (1.6 x 3.2mm) and 0805 (1.25 x 2.00mm) are some of the smallest. I have to say, I can solder 1206 pretty well, but 0805 are very hard to work with using a normal soldering iron. There are smaller LEDs too - 0603; I can’t imagine trying to hand solder those.
Litchfield Station and Richmond Controls are two DCC suppliers that I know of who supply SMT LEDs with six inch leads already soldered to the LED. In a previous response in this thread, the lower light is the one with a six inch lead soldered to the LED. The LED is a Golden White 0.06" X 0.03" or 1.5mm X 0.76mm. Dig out your caliper. The resistor in the photo is 1k, the resistor most commomly used for LEDs on DCC decoders.
Thanks guys ill put your inputs as first proirity the second one…how to solder these bad boys in a set… if you are wondering why,…well have you heard of the Canadian Pacific’s Holiday Express?
