Micro Engineering Ladder
i’m planning an expansion to my HO 14’ x 3 ’ industrial layout and would like hear comments / reviews on the ME Laddder System. I currently have 18 Peco Code 100 insulfrog turnouts and use Tortise switch controls combined with Caboose hand throws. I would like to transistion over to Code 83 flex track for the expansion which will include long storage & staging yard, but i’m not sure on the best switch machines to use for this ME turnout system because i don’t know if the ME switches have a builit in springs like the Peco switches?
Bayway Terminal NJ
They do. The old single digit turnout motor on the end of the articulated arm works fine, depending on how tall you are and the elevation of said turnout above your feet.
Thye Micro-Engineering Ladder System is very effective in fitting a five track yard in a space where you could normally only get four. It saves a lot of cutting, and everything works/fits very well.
The one I am familiar with was powered by Tortoise Switch Machines.
Be aware… this is a trade-off. You get more tracks, but you cannot get your fingers in there easily, and seeing car reporting marks becomes more difficult.
-Kevin
The ME ladder system developes a ladder with a 16.2 degree angle (sharper than even #4 turnouts, but uses 11.42 degree #5 frogs.
The turnouts are shorter than standard #5’s, and they curve after the frog, as many prototype yards do.
They deliver a yard track spacing of 2.1" as recommended by the NMRA.
Personally I have always spaced all my parallel tracks at 2" centers, yards, mainlines, even curves with the 36" and above radius I use.
So, the ME system does pack the ladder in a smaller space, but still at the risk of some larger equipment, especially steam lococs, not liking the tight closure rail radius of these compact #5 turnouts.
If you locos are small, it is likely a good system. If you need for mainline steam power to enter any yard track, maybe not so much.
Sheldon
Wow, 2 inches is tight. I usually space my tracks at 2 3/8" or 2 1/2" centers.
I just mocked it up with some freight cars on my work surface grid. I need a more relaxed spacing.
-Kevin
2" is still wider than most prototype parallel trackage, and is the defacto standard in the industry going back to the 40’s.
Atlas track, TruScale track, Campbell Scale Models bridges, Walthers bridges and crossovers, Sinohara crossovers, Central Valley bridges, and many more have 2" centers for yard ladders and double track items.
Sheldon
Yes, I need one portion of track at 2" center for my Shinohara double crossover. I just prefer wider spacing where fingers need to go, especially in the yards.
If I remember correctly, Walther/Shinohara “5 turnouts result in a 2 3/8” spacing without trimming the turnouts.
Simply my preference.
-Kevin
2.1" is a former NMRA recommendation.
The current recommendation (NMRA RP-7.2) varies by the era of your layout. For HO:
Old Time: 1 21/32"
Classic: 1 25/32"
Modern: 1 15/16"
These are minimums.
Paul
Yes, another in the long list of minor revisions over the last few years.
Sheldon
2" is a nice round number, easy to work with. Great for straight track. It is generally too close for curves, unless you get into extremely large curves - I know from experience that full length passenger cars will not work at 32" radius with 2" centers, it needs to be widened. Maybe 40" radius curves will work with 2" centers.
But for straight parallel tracks - 2" looks good and there should be no clearance problems unless you have a shifted load on a flar car, but then the prototype has the same issue - just another reason they tell you to keep your head and arms inside the car at all times.
My minimum radius is 36" and I have never had problems with 2" track centers, even with long passenger cars. I do aso use easements.
Sheldon
Thanks all for the info, i currently have 2’’ spacing for the most part in both of the opposite-end yards and outside lead & by-pass tracks. Also glad to hear i can use tortoise machines for the expanison and that ME switches have springs. I only run diesels on the layout, rolling stock consist of 40’-53 ’ intermodel cars and steel mill cars of all sorts. The expansion area will have a graduated 32" radius single lead track coming off one end of the shelf layout eventually connecting to a WYE switch, with a long single track leading into to the ME ladder system. I haven’t yet decided on where the other WYE lead track will end up? Bayway Terminal NJ
Sometimes we forget that the biggest space consumer for any yard is the tail track, or whatever it’s officially called. Long sidings require an equally long tail track at the throat.
Thanks & understood. Bayway Terminal NJ
How about the track layout as shown in the attached photos? The minimum effective length will be longer. However, it has no geometrical beauty and requires advanced surveying techniques to lay railroad tracks. This place is near Shin-Osaka Station on the Shinkansen and is the Miyahara Passenger Car Yard. See also my blog post.
Google Map
Postscript: Of course, the total number of cars detained will be reduced.
That underlines an important difference between a mere storage yard and a sorting yard.
My balloon track does double dutie for that. My yard works quite well. I have two A/D tracks at the far end and pull the cars into the balloon track and then push them onto the ladder. I have no idea where it falls on the prototypically correct scale but it works for the small space I have. Sacrifices don’t you know.[(-D] I will be moving the ladder tracks closer together at some point as I have no need to get my fingers in there.
For a long time I have been meaning to invite some critical thinking on what I have before the cement sets.
I had planned to look at the ME Ladder system for a future layout change. However I will be running long Autoracks and Superliner equipment through this yard. Sounds like this longer eguipment will not fare well with the tight turnouts. Is it the turnout angle? They seem to do well with a std #5 turnout, at low speeds anyway.
We do something very similar by using the connecting mainline between two continuous running loops, (each loop also contains a reversing loop, one of those continuous running loops includes two crossovers spaced by about 12’ creating two facing reversing loops.)
The length of mainline between the yard throats and the access to the main running loop will hold a pretty long train. For even longer trains the switching locomotive can borrow part of the longer of the two running loops (our main running loop).
Usind three DC throttle (power packs) block
Officially, those ME ladder turnouts are #5. They compress by curving the diverging route I believe. Measured with a set of trammel points to be 26" substitution radius and this is confirmed as correct for #5 frog from another source.
