micro enginering turnouts
has anybody used Atlas selectors to control the frogs on micro enginering n scale turnouts?
Atlas Selectors are primarily used for common wiring block control but to power the rails on a select control turnout, they can be used though it’s overkill because you’ll use only one of the four posts that come with the Selector…attach the wire from the track to the first post on top of the selector and then the power wires (the top and bottom post on the left side of the Selector can go to the inside rails of the straight and diverging track of the turnout…Chuck
