Midwest Connect Proposed Service
Chicago to Pittsburgh passenger service proposal. Preliminary stage.
It seems like Columbus is kind of out of the way to get to Pittsburgh.
Not if you go by way of the old B&O route… and the high-speed PRR route across Indiana to get to Pittsburgh would be very expensive to restore as a passenger route (although you could reasonably ‘branch’ it just as PRR did for high-speed access to St.Louis too…)
Note when they say ‘Midwest Connect’ they may be talking how much connection they do, not how fast or competitive it would start out being…)
What needs to be connected between Chicago and Pittsburgh are all the other cities of the mid-West. Indianapolis, Columbus, Cincinnati, Detroit, Toledo, Cleveland, Akron and St. Louis.
A single line won’t do it.
A single line, or an approach to a City of Everywhere train, likely won’t.
The model is going to be what the states agree to pony up to get rail connectivity to their cities. And I’d argue that the ‘correct’ solution isn’t going to involve one-seat service with sections from off-main cities being switched in and out of a consist… FLIRT-style distributed power packs substituting for extra locomotives notwithstanding.
That leaves us, again, with the luxury Thruway bus service as the Midwest feeders in my opinion. It might be interesting to see how far we could get toward the Pickwick Nite Coach level of onboard service…
It’s just a beginning. Maybe it will develop into a network, maybe not. Chicago to Pittsburgh could offer a connection at Columbus to Dayton and Cincy and onward to DC and NYC at Pitt. Other lines might follow.
The logical connection with a ‘Midwestern’ train would be with the Cardinal at Cincinnati for all the ‘northeastern’ connections (ultimately via the NEC). That would keep the ‘Columbus’ train able to terminate at Pittsburgh even with no organized through-Pennsylvanian to Harrisburg… at least at first.
  1. Cardinal already runs to Chicago 3x per week.
  2. A ~28 hour schedule is pretty slow.
End to End is not the forte of at MW Connector. I will have to be a nominal Hub and Spoke type of undertaking simply because of the geography of the population centers.
That would be for the best. Trains can only compete in the <300 mile segment.
The problem with Columbus is that the majority of its population growth has been relatively recent. Cleveland and Cincinnati have better rail connections since they were always considered to be the “big” cities in Ohio. In 1950, Cleveland’s population was 914K, while Columbus only had 375K. In 2023, Columbus has 913K and Cleveland 364K. They’ve almost exactly swapped populations.
It’s clearly why connecting Columbus makes sense. Amtrak should go where the people are.
Too bad there’s no Chicago Columbus Panhandle line anymore to allow a direct fast route.
Expecting meaningful support from the Ohio General Assembly for this project is like expecting Lucy to finally let Charlie Brown kick that football
What my geographical understand of the Midwest would indicate -
Pittsburgh, Chicago and St. Louis as end terminals. Indianapolis & Columbus as hub terminals and spokes, in some manner, going to Cincinnati, Cleveland, Akron, Toledo, Dayton, Fort Wayne, Evansville, Springfield .
No love for Detroit or Grand Rapids?
Out of sight, out of mind. Does’t Grand Rapids already have service to Chicago?
…when they are awake.
I kinda like the route. Pittsburgh starts looking like a hub.
Devil is always in the details, though.
They do, funded by the state of Michigan. The fact the state doesn’t fund a train to its largest city from GR says a lot.
New Detroit rail hub plan
One would expect Michigan to have an entire network in the state radiating out from Detroit.
