Mikados on the Cumbres and Toltec
June 1, 2018 and we come to Chama New Mexico to video D&RGW 315 making a special freight run from Antonito Colorado to Cumbres Pass and back. That video is available here: https://www.youtube.com/watch?v=cSPo98tjTkE
We are also here to document the second weekend of the season and feature D&RGW locomotives 484, 487, and 488.
The Denver and Rio Grande Western K-36 class are ten 3 ft narrow gauge, Mikado type, 2-8-2 steam locomotives built for the Denver and Rio Grande Western Railroad by Baldwin Locomotive Works. They were shipped to the Rio Grande in 1925, and were first used along the Monarch Branch and Marshall Pass, but were later sent to the Third Division out of Alamosa. Of the original ten, four are owned by the Durango and Silverton Narrow Gauge Railroad and five by the Cumbres and Toltec Scenic Railroad Number 485 fell into the turntable pit at Salida and was scrapped in Pueblo in 1955, with many parts being saved.
The locomotives are of outside frame design, with the driving wheels placed between the two chassis frames which support the boiler, but with the cylinders, driving rods, counterweights and valve gear on the outside. This general arrangement is shared with the earlier K-27, K-28 and later K-37 Mikado engines.
The locomotives’ name of K-36 comes from two different sources. The K in the name comes from the locomotives’ wheel arrangement (Mikado), and the 36 stands for 36,200 pounds of tractive effort.
The K-36s were used primarily as freight locomotives out of Alamosa to Durango, and to Farmington, New Mexico, as well as out of Salida to Gunnison (over Marshall Pass) until 1955 and to Monarch on the Monarch Branch until 1956. They were built with special valves to allow brake control between locomotives while double-heading, and were commonly found between Alamosa and Chama, New Mexico. They were heavily used during the pipe boom in Farmi
The 480s also continued up the Crested Butte branch, hauling out CF&I coal which kept the Marshall Pass line busy into the early 1950s.
Yard Limit,
A very nice account of the D&RGW narrow gauge Mikado engines. It should also be mentioned that the reason for the outside frame design was so that the engines could be easily converted to standard gauge track by merely changing axles and placing the wheels outside the frames of the engines. This would only be necessary if “heaven forbid” the railroad decided to abandon the “narrow gauge” and re-track the railroad to 4’ 8.5 inches!
Dr. D
Thank you! I didn’t know that.
Well that’s a new wrinkle on outside frames vs. the usual explaination that outside frames allow larger boilers to sit with lower center of gravity over the drivers for stability.
