I’m a little stumped at the moment but is the milk car platform 3462p only for O27 track? Im using O guage tubular and have the UCS remote (6-65530). The platform does not look like it adjusts. Thanks in advance and Happy Thanksgiving!
The steel deck slides out and you can choose the lower slats for “O-27”, or the upper slats for “O”.
Maybe this platform is missing something because I see nothing that slides.
Time out. It currently is missing the deck. Im probably trying to put the remote section in backwards. Where the wires hook up should slide in underneath where the deck goes?
It is designed so the entire UCS slides in and up from the bottom, with the wires running under the platform and out the notch / cutout at the rear of the structure, without having to disconnect the wires at all.
If the deck is missing, there is no place for the cans to sit or be deposited, at level with the milk car doors.
Thanks Rob, I was trying to put the UCS in backwards causing my blank stare. I ordered a deck the other day so all should be well. Thanks again.
