9-pin DCC Decoder wire harness with JST connector such as a Digitrax DHWH
Dremel Tool with #194 metal cutting bit or similiar
Snap Saw
STEP ONE:
Remove couplers and body shell per Intermountain instruction sheet. For the following refer to the above photo.
Remove the speaker mounting bracket, speaker, rear truck and coupling linkage.
Use a Dremel Tool with the #194 bit to cut a notch in the rear of the locomotive frame approx. 3/32 inch from left rear edge, and 7/64 inch deep at top edge of the frame. Square up notch and check LED for clearance.
STEP TWO:
Cut 4 pin section from 9-pin wire harness using a snap saw. Plug into socket on QSI decoder as shown below:
I’m happy to report it works in DC mode as well! Thanks for asking the question; I did not think to add it to my opening comments in the post; I’ll edit them now. Let me know what you think when you modify yours. The cool thing is this LED is great for headlights, lighting car interiors and other uses for a bright light that doesn’t heat up and draws very little current.
This is excellent! You should consider forwarding this to the MRR staffers as this would be a great article they may want to post in a future magazine issue.
Is this procedure similar to what can be done with P2K E units?
This is GREAT! I can’t say that I will probably use this particular clinic, but I am so glad to see it. Personally, I would love to see much more of this type of activity on this forum. This is the whoe reason I joined this site in the first place. This is real, helpful modeling info. Thank you for offering it.
This is a great little mini clinic. I added reverse lights to my three Intermountain Ontario Northland FP7s using the info here. I also programmed the following CVs to get the light effects listed below. The CV changes below will only work with the Version 7 upgrade chip and not with the chip the loco was shipped with ( Version 6 ).
CV49 to 70, CV50 to 1, CV55 to 170. This lets the F0 key ( headlight master on/off ) turn the headlight(s) on and off. Once the headlight is turned on with F0 it will remain on in foward, neutral forward, reverse and neutral reverse.
Cv49 to 73, CV50 to 1, Cv55 to 165. This lets the F0 key turn the rear light(s) on and off. Once F0 is set to ON the rear light(s) will be on in neutral reverse and reverse. It will go out when the loco is set for neutral forward or foward.
CV49 to 70, CV51 to 0, CV55 to 160. Then CV49 to 73, CV50 to 0, CV55 to 160.
This allows the headlight and reverse light(s) to remain off during sound startup ( lighted number boards will still come on during startup ). The F0 key will turn them on after startup ( reverse light still only comes on in reverse with F0 key toggled on ). If the F0 key is left on during unit shut down the headlight ( and reverse light if the loco was left in reverse during shut down ) will light for a second then go out during the next startup. The F0 key will have to be pushed a couple of times after startup to turn the headlights back on.
Thanks folks for the kind comments! Thank you jjjwar for the added information for programming; I posted the information prior to the version 7 release and did not think to update it, so I am glad you did.
