I made some modifications to my original minicam car to make it blend in a little more. I installed the car’s original body. I drilled a hole in the roof for the switch, and one in the end for the camera. The body slips off for battery changes. I had to remove the camera mounting bracket, because it sat too high. I use double sided tape to attach a thin (1/4") block of wood to raise the camera off the floor. It was too close to the track, making the foreground blurry. If you look close, there is a “1” and a “0” on either side of the door. These tell me the switch position. Once I had the holes drilled, I rattlecan and chalk weathered the car. I also used my Micro-Mark truck tuner to replace the stock Bachmann (yes, this is a Bachmann car that came in my original Overland Express trainset) axles and wheels. Needless to say, it rolls a lot better, too.
On my subway-car minicam, I have a pair of slide switches mounted on the bottom of the car. One turns off the camera, and the other turns off the pair of LEDs I’ve got mounted as headlights to illuminate the tunnels for the video. These mini-switches (from Miniatronics, as I recall) are not visible unless the car is lifted off the tracks. Yeah, I have to lift the car up to flip the switches, but that’s no big deal.
I was wondering if you could mount your toggle switch on the end of the car. I think there would be enough space between that and the next car.
When I made the car, all I had on hand were the mini-toggles. I plan on replacing it with a mini pushbutton on/off switch, and leave it mounted on the roof. And, if I paint it to match the roof of the car, it’d hardly be noticeable at all. But, I DO appreciate the feedback.
