Manufacturers build different models for different markets. The majority try to adapt their product lines for 22" - even at the expense of realism - to sell MORE product. (one example is BLI)*, Is it justified? Is the proverbial ‘tail’ wagging the dog?
Actually the minimum curve size depends on the layout size.Got a basement? Wider curves…A 4’x8’ smaller curves.Got a 5x9 footer then a little wider curves.
Yes,its justified as the manufacturers knows that everybody doesn’t have a king size basement for a layout or access to a club.Therefore they must consider these cold hard facts while designing a new locomotive or long wheel base car…And I thank God for that as everybody can enjoy the new product instead of a select few with basement size layouts or access to a club…It makes good marketing sense that they cater to all modelers which means more on the bottom line.
I think it’s justified Don.
A lot of us don’t have a lot of space to allow for wide curves that will make the longer locomotives & cars look as ease going around these curves.
My layout is 9X12 & while I could fit larger curves, I’d loose a lot of space for industry & other potential customers.
So far I haven’t had any problems with the longer cars & locomotives I have.
KNOCK ON WOOD
I have one spot, in an industrial area where I used an 18 inch radius. The ruling radius is 22 on my layout and I wish I could have gone bigger. I have a turn back loop with a 24 inch radius that is on a grade. The rest of my radius on grades are far above 24 inches.
My minimum mainline radius is 23 1/2". Some curves are larger. If more space were available I’d go to a larger minimum. 30" minimum would be nice. I do believe that manufacturers are justified in engineering locos to run on tighter curves. It makes running them feasible for a lot more people.
Have Fun,
Tom Watkins
I voted 28+. Actually my mainline is a 34" minimum, mostly 36". But I’ve found out that I’m going to have to re-lay a section with 30", which makes me nervous, since I’ve got several 2-10-2’s which are VERY sensitive to small radius (30" or under). So I’m going to have to be extremely accurate putting that section in. A lot of the current steam these days is designed for 22" or larger, which puts it in the realm of modelers who don’t have room just yet for larger radii, or are just getting started. Myself, I don’t mind the smaller compensating driver size, as long as the product works and is available. Even with my wider radius curves, I tossed out my driver size scale rule a long time ago. I mean, if I’m going to use code 100 rail (larger than the Pennsy of fond memory, I understand), then I don’t care if my 4-8-4 has 72" instead of the prototype 79". Just as long as it stays on the track.
My HO minimum mainline is 26" with 24" on branchlines and 18" for yards/industry. I never really figured out how to get the large radii without messing up the planned scenery and industry. There are a couple of curves where the passenger trains look like a dislocated centipede [(-D] , but otherwise all look good winding in and around the mountains and other scenery.
Yes, I am glad manufactures provide for the smaller layouts. Sometimes there has to be a compromise in realism for practicality. An example would be if your train travels to the next town which (in mind) was 100 miles away, it’s unlikely you would lay down over 6000 feet of track to stay in scale.
12" in HO scale. All are formerly-interurban curves through city streets. My only passenger equipment are trolleys, for which 12" radius is a splendid sweeping expanse of curvature…
My HO layout has a minimum radius of 22" - with easements. If I build a new layout, I will use a minimum radius of 30". I built the present layout in 1987 and ran mostly Athearn first generation GP’s and Atlas RS3/RSD5’s with 40’ freight cars(modeling the 50’s). Over the years I have upgraded the ‘fleet’ and my P2K SD7’s really have problems getting into spurs(coupler overhang). I do run BLI USRA 2-8-2’s as well on the 22" curves, but any future construction will be a minimum of 30" radius and #6 turnouts.
I went with 26"-36" on the mainline(s)
nothing less than 24" on everything else…
15" and 18" will work…but your engines and rolling stock have to be short…
