I know that I’ve seen it listed before…but I’ve been searching
and can’t find it. What is the minimum radius for a Beep?
I’ll be using flex track so if it’s less than the smallest available
premade that’s ok. I need to build a display in the smallest
space possible.
Thanks!!!
underworld
There was recently a thread on the OGR Forum where I believe it was stated a Beep would run on SuperStreets track, which makes a 21" diameter circle. You may want to search OGR to be sure.
Frank
Awesome, thanks!!!
I have used mine on 027 without any problems but it has a hard time going over switches even as big as 042.
I haven’t tried it but I’ve been told it will run on the 16" radius superstreets.
Thanks guys!!!
