Misc R.R. Revenue
I thought rairoads only got paid for moving cars from piont A to point B. Are there other ways that railroads earn revenue?
TIM A
Hi Tim, Sure.
We use MK1500D switchers. I know, you never heard of them. Thats because as far as I know, only one order was built. #s 9601 thru 9624 were built for the PTRA, and 9625 thru 9630 were for the now defunct HBT, (houston belt and terminal) as a joint order from Morrison Knudeson, MK, which became Boisie Locomotive, which is now owned by EMD. The belt locos went to BNSF when they took over their part of the belt. Boisie also built MK6201, a six axled switch engine,(SD 40 chop job) and the 1501, also a MK1500, but AC traction motors. Both of these are demo/lease units. All the MK1500 are B-B units, meaning 4 axles per truck, each axle powered.
As to how we see out of the Big motors, depends on the make of engine, and what your doing. Backing up, the engineer most often watches a crew member who is on the rear, giving hand signals. When using raido signals, where he looks is up to him, as he responds to whats said, not what he sees. As a safety precaution, on of the most important rules from the GCOR rule 5.3.7 states “radio communication for backing or shoving movements must specify the direction and distance to be travled, and must be acknowledged when distance specified is more that four cars”, futhermore, " movement must stop within half of the distance specified unless additional instruction are received".
If you tell your engineer to back up ten cars, he will repeat the instructions, and begin to back up.If he dosnt hear for you after he travels appox 5 car lengths, he will stop.
This keeps yofrom shoving out of a track, or through a bumper, ect. As a added benifit, what if your raido failed, or you fall off the train, the train will stop reguardless.
If you go to PTRA on your search function, you can find a nice series of photos, showing the MK1500D we use. They have great visibility forward and back. At one time, the most often seen switch motors were EMD SW6, SW9 and Mp15s. These followed the design of long hood forward, due to the idea that any accident/collision,
You bet, stay tuned. gdc
As a way of introducing this subject, I’ll try to answer your question. Miscellaneous charges, that is billing to customers by the railroads, are for services ancillary to but not necessarily involved with direct moving of a car. For instance, the various types of demurrage. Demurrage is a charge to a customer for excessive detaining of a freight car for loading or unloading. The purpose of demurrage is to encourage the prompt release of an empty or forwarding of a load, so as to provide the railroad a reasonable return on the investment of its equipment. A box car not moving is not producing revenue.
There are other miscellaneous charges as well. As these posts go on I’ll talk about them as is appropriate and as long as interest is there. Other miscellaneous charges may be the various types of switching, weighing, transit charges and other services indiginous to a particular location. On the former N&W, there was even a miscellaneous charge for koshering. There was a Jewish owned customer who received perishable goods by the carload. Since this customer was an orthadox Jew, he desired to have the load koshered before it was unloaded. The railroad had an agreement with a local rabbi to do just that. When a car arrived, the rabbi was called, he came and the load was koshered. The miscellaneous charge to the customer was $25 per car, if I remember correctly, which is what the rabbi charged.
Since Ed, from Houston, expressed an interest in discussing chargeable switching, let’s go there first. Right off the top of my head, I can think of 5 types of chargeable switching.
  1. Intra plant. This is switching of cars from spot to spot within a customer’s facility. Since nothing in railroad billing is simple, there are instances where intraplant switching is not billable to the customer. We can discuss this more in a future post.
  2. Inter plant. This is switching between two customers, maybe even the same the customer with two facilities.
  3. Intra termin
Really good opener, and yes, better as a seperate topic. Wonder if anyone will bite on AAR billing/bad order & car repairs?
Good start.
Ed
I wonder too. However AAR repair billing is a mechanical function as opposed to rail operations. If this discourse continues, I will get into that down the road. There are also money sources in land leases and sales, building and property rents, coal, gas and timber royalties as well as profits from investments and industrial development projects. Ed, thanks for your input. I am trying to keep this as an overview. gdc
As further response, there are areas of other interline settlements as well. Revenue, car hire and freight claims come to mind. These are other facets and, for clarities sake, should be discussed seperately methinks. Have a safe day! gdc
On the intermodal side of the house, there are some others. Most notably storage fees for empty steamship containers and chassis. Sometimes storage is worked out as part of the rate, given certain traffic volume and amt of equipment.
Thank you for your comments and I apologize. It was not my intent to exclude intermodal ops and the areas of trailer/container/chassis storage is a revenue source. We had begun to focus on switching which is indiginous to rail operations. If we go that long, we can also discuss intermodal revenue sources. After all, it’s one of the few volume growing areas of the industry. gdc
The railroads charge for switching cars at line customer industrial sights? I thought that spotting cars was added into the shipping costs.
I thought the railroads dropped off the cars at a customers sight for free. Is that not correct?
TIM A
Tim,
Line-haul rates include the pulling of a car from original loading spot and the placing of a car at its final destination. Sometimes customers want additional switching. This more than likely occurs in large facilities with multiple tracks but isn’t limited to that. The first type of chargeable switching I will talk about is intraplant. Hopefully it will explain some of your questions. Stay tuned! gdc
Hi Tim,
You bet we charge to move cars within a plant. It is one of the most common moves we do on a terminal RR. Example.
I am going to pull and spot a plants loading track #6A.
I have work orders showing 4 pulls, 1 move and 4 spot cars.
Their track #6A has five spots, specific locations where cars are placed, usually under a loading/unloading pipe rack or at a warehouse door.
Spot 1 is nearest the main, spot five at the back of the track. I am going to describe the moves required, so you can see why we would charge someone to move a car already in their plant. My work order shows the customer wants the cars from spot 1, 3,4&5 pulled and sent to the carrier of their choice.
However, the car on spot 2 is a “setback/move”, the customer now wants it moved to the 5 spot to unload it.
Remember, I also have four “new” cars to spot in the plant.
We would cut off from our train, leaving it on the main, reach in and pull all five cars from the plant. Set three cars to the main on top of our train, (spots 3 ,4 &5) and set the car from the 2 spot back in the plant. We would then get back against our train, which now consist of a locomotive followed by four pulls, (#s 1, 3 4 & 5) and four “new” spot cars. The customer dosnt care what order the new spots are in, but the car from #2 must go to the #5 spot. We drag up, come back against the car we put back in the plant, (old #2 spot) and shove back to the #5 spot, cut off, and then spot #s 4, 3, 2, and 1, with the “new” spot cars,cut away and leave the plant with the old cars from #s 1, 3, 4 &5, our “pulls”. Now remember, there is a lot more work involved, this is very simplified. We have to couple up the cars in the plant, as they are usually seperated, lace up the air hoses, cut in the air, check with a air guage the brake pipe pressure at the rear car, and do a walk set, (visual check to make sure all the car brakes work)
So you see, it isnt just a matter of “grab and go”, it can require a lot of complicated move
I think that a new can of worm has just been opened Ed for people who do not work for the railroad`s do not realy understand on how we generate revenue to keep it running 1. being the cost of diesel fuel to run the locomotives 2. the cost of labor for the switch crew i.e. the engineer, foreman & helper it takes time to do the air break tests when car are pulled from the industry i.e. air flow or break pipe leakage in the absents of an air flow meter the AFM test is easy as long as the train is 60 cfm or below the break pipe leakage takes 3 minutes to do before doing any of these tests the train air system has to be fully charged to operating pressure as per the GCOR 80 psi for yard and 90 psi for road walk the set up of the breaks and take the walk it can take some times over an hour to a simple move of 8 cars out and 8 cars in there is no such thing as a fast move when ever the crew gets in a hurry things can go wrong. Rodney Beck Switchman/Foreman BNSF Chicago Division Galesburg Terminal
Property leases, track Leases, car hire revenue, demmurage, special train moves, asset sales, switching charges, car repairs, any shop work for others, just a few other ways
Ed had explained what one type of chargeable intraplant switch would be. In essence, if you change the remaining lineup of the track, then a switch charge is applicable. You could even move remaining cars from one door to the next as long as you didn’t exchange spotting locations. For instance, consider a single track with 8 spotting locations, 1 thru 8 beginning at the closest to the switch. There are cars in spots 2, 3, 4, 6 and 7. The carrier arrives with a car that the customer wants at spot 4. At the same time, the customer wishes to pull the car presently in spot 4. Additionally, the customer would like the cars all coupled together in spots 8, 7, 6, 5 and 4. Since this did not change the lineup of the track other than to spot and pull, there is no chargeable switch. If the remaining cars had been moved around each other and respotted, then there would be a chargeable switch. This has complexity been a point of contention between the carriers and customers for years. Some undertand it and accomodate the charges and some never do. Other customers try to take advantage, especially if the encounter an inexperienced train crew.
Other types of chargeable intraploant switching would be from track to track in a larger facility. This would be done to complete loading or unloading. Line-haul rates include the spotting at one loading location and/or one spotting at the destination. A strict interpretation of this would be switching an extended load to an idler. Let me describe this to those who may not be familiar. An extended load is one that is too long for one car, such a bridge girder. In order for the car to be handled in the train, a flat car is provided to accomodate the extended end of the girder. If the loading spot can not accomodate the idler, the load has to be switched to it from the end that can be reached to complete loading—a strict definition of completing a load. Whether that is a chargeable switch has been the subject of heated conversations between carriers and customers
Right you are. Check outg the posts of 12/5 at 9:41 pm and the one from Donald on 12/6.
Ed, at NS we never charged for a car facing in the wrong direction. In the case of an opposite nozzle or a placard directing unload from the other side from the spot, we would turn the car without charge. The logic is that it is the carrier’s responsiblity through line haul rates to spot the car for the customer. As I think about it, it probably is different for a terminal carrier, since they usually do not participate in line-haul revenue. I don’t remember that ever coming up with the switching carriers I’ve been involved with. gdc
WOW, I did not think that switching cars could be so complicated. You mention air brake testing, if your moving a car a short distance why do you need brakes isn’t the engine powerful enough to stop the car on its own? Moving these cars sounds like alot of reversing. Do they use two engines facing away from each other? If your useing one of those new big engines, how do you see out of them when in reverse?
TIM A
If you derail a train while doing this work who pay’s to get everything fixed?
