Mix match F3/F7 A/B Units
There were differences in locomotive control schemes that caused problems at first. Through the F3 model, the transitions were all manual. With the advent of the F7 model, transitions became automatic. Trying to use an automatic cab with a manual transition booster could cause problems because the older booster didn’t speak the control language of the newer cab. But eventually the older units were fitted with controls that were interchangeable.
Some FT units in later units were regeared and ballasted with concrete for use in drag service in combination with newer units. This was done because as they were originally built they couldn’t use their full horsepower at the slower speeds the newer units were capable of. But with regearing and extra ballast there was new life in old units. As long as the prime movers were in good shape life was good.
I have photos of all kinds of curious power combinations including rather amazing assortments of geeps with a cab unit booster thrown in the works for good measure. One I remember well was a photo of a GP40 coupled to a GP7, one unit being exactly twice the horsepower of the other. Again, the combinations were almost limitless and there were only a few combinations that couldn’t be made to work together. Baldwin units had pneumatically controlled MU interfaces and they couldn’t be used with those that had electrical interfaces, so that would be a no-no unless the Baldwins were used as a tail end pusher or something like that. But otherwise, the only rule was if it works for you, try it. I find it fascinating to see the interesting combinations that appeared over the years and I like to model these in my own private world.
One combination on the Union Pacific that got quite a bit of useage was putting an E8 or E9 A unit with a F9 B unit to make a locomotive with a total of 3,900 horsepower. Union Pacific used a lot of these combinations in freight service after the demise of long-haul passenger service. They were very effective. There was
On the flip side, the Chicago & NorthWestern often used an E unit and and F unit (both A cab units) together on passenger trains.
Huh???
I always thought that’s what circuit breakers did - shut down an electrical circuit in case of an overload!!!
On every EMD on which I’ve turned a wrench – Dash-2 and older – there is no current-limiting device. No circuit breaker. It would be a bad idea to have one! There is a ground relay to detect shorts to ground, but that’s not the same thing.
The drawback to a circuit breaker is it cannot tell if the overload is intentional or not. By enabling very high currents for very short times, which are within the capability of the D.C. traction motor for at least a minute or two, the locomotive can start a much heavier train that it would otherwise could if it was current-limited by a circuit breaker. Yes, it does require the engineman to pay attention to the short-time rating on the ammeter, but that’s not unreasonable.
Different short-time ratings between the different EMD models is for practical purposes inconsequential. The ammeter needle is dancing around in a narrow band on a dial and at very heavy loads the short-term rating is, for example, 2.1 minutes for one locomotive and 2.0 minutes for another. If an enginemen loads his power into that regime all of the motors – not just the weakest ones – will be smoking.
For models where short-time differences was consequential, such as between 4-motor and 6-motor locomotives, EMD included power-matching circuitry to ensure that the 4-motor locomotive had similar motor-heating curves as the 6-motor locomotive it might be in consist with. For example, in the Dash-2 line the PF21 module derates the GP40 from 3,000 traction hp at 22 mph to 2,200 traction horsepower at 11 mph, or about the same hp per motor (500-550) as the SD40-2 it might be m.u.'d to.
RWM
