[quote user=“tomikawaTT”]
Woorking in what will be hidden staging and thoroughfare track, I have been mixing hand-laid specialwork with Atlas code 100 flex, frequently stripping ties off the flex and spreading the rails, then building the rest a turnout on wood ties between and under them. If the stock rails are long enough, they might end up having lengths of flex-track ties reinstalled (I’m careful not to break the plastic ‘spikes’ as I slide the ties off the end of the flex track.) The flex track does have to be shimmed up to match the rail base height on my wood ties.
Working down from the top, my structure consists of rails, 1/8 inch medium balsa ties, a layer of grey latex caulk, a cardstock template exactly the dimensions of the turnout ties, another layer of caulk, a layer of thin foam (fan-fold underlayment) and the cookie-cut plywood subgrade. Using thin-shank spikes, that seems to hold about as well as driving them into soft pine. The rubbery caulk seems to grab the spikes and hold them down, while the ties and (especially) the cardstock provide lateral stability.
My oldest ‘new’ specialwork has gone through a complete cycle of seasons now, and is still performing flawlessly. (To put that in perspective, the layout space is NOT climate controlled, will be below freezing at dawn tomorrow and can easily top 115F in mid-August.) Since I run trains almost daily, any problem would be easy to detect.
Hope this has been helpful.
Chhuck (modeling Central Japan in September, 1964)
Thanks, tomikawaTT, that was a very good description of how you do these handlaid turnouts with flex track. I have not been brave enough to tackle handlaid track, let alone turnouts but my free-lanced Toledo Erie Central, a small switching layout, has some rather tight places where I am considering replacing the commercial (code 100) turnouts with hand-laid, to accommodate the need for the sequencing of turnouts in a much closer fas
